Showing results for tags 'tl2 manual video setting'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 1 result
  1. Hi Everyone, Is it possible to set the exposure (time, aperture, iso) and the white balance manually in video mode? The manual says: "The automatic exposure control takes all brightness fluctuations into consideration. If you do not want this, e.g. for landscape pictures and pan shots, you should set the shutter speed manually. " I tried but I can't. It doesn't matter what I set in photo mode the video mode always set another white balance and automatically adjust brightness wile I record and the exposure is way off. My other question is is it possible to lower the sharpening and the contrast in video mode? I found the final video is very over sharpened and has very high contrast. Thanks
