Showing results for tags 'sync speed'.
Found 1 result
  1. In the manual it says that the SL will sync with flash at 1/250. When I use the camera with Bron Visatec strobes I can only sync with 1/160 sec or slower. Using faster shutter speeds will result in a image that is dark in the bottom due to the shutter blocking the sensor when the flash goes off. Am I wrong?
Γ—
Γ—
