Showing results for tags 'sony leica sl wedding'.
Found 1 result
  1. Hello all! I am a wedding photographer currently in the Sony ecosystem I am in the process of purchasing an SL. I use a Sony 24mm 1.4, Sony 35mm 1.8, Sony 55mm 1.8 and an 85mm. I use the 35mm 1.8 about half the time. Next most used would be the 55 about 30%. The 85 for mid tele and formal portraits and the 24 for the wide shots and in the dance floor. In your opinion, which autofocus lenses should I consider as I slowly sell my Sony gear away? I am hoping to keep the cost of switching systems at the lowest possible and I don't mind third party options. I hope to eventually have the same prime setup. If you have any tips in lens choices I should take a look at I would really appreciate it! Thanks you lads!
Γ—
Γ—
