Showing results for tags 'sl2 profiles'.
Found 2 results
  1. I’m current SL2 owner and very recently received my SL2-S. I’ve tried to import my SL2 profiles into SL2-s but on every occasion I get an “import failed” indication. I’ve repeated the process with multiple SD cards with same result. I assumed that being that only difference between the cameras is the sensor resolution that sharing profiles would be pretty straightforward. I spent a lot of time creating multiple profiles for different shooting situations so was hoping to avoid having to go through the entire process all over again on SL2-s Would appreciate guidance from anyone who has figured out how to accomplish this task. Alternately please let me know if what I’m attempting to do simply can’t be done. Thanks.
  2. New user, had set up some preliminary profiles. Inspired by latest reddotcamera youtube show on menus, I wanted to make some changes to existing profiles (using FW5.0). I have performed these types of changes on other systems, am confused as to whether it can be done, and, if so, how. 1. It seems that every time you turn on the camera, you must change the Profile from Default. There seems to be no way I can find to have it start up in either "last used" or a different "default" custom profile (such as Tripod). I find this annoying. Am I missing something? 2. There seems to be no way to modify and existing profile and have it updated to the modified version. Looks like you make a change (from, say MF to AF), and you must save it as a new profile, so you wind up with the original profile plus a second modified profile? Again, am I missing something? Thanks, Rick
