Showing results for tags 'missing petals'.
Found 1 result
  1. there was a long strip at the roadside but I discovered they were past blossoming. Sunlight was too low to light their heads. So I used a flash being bounced against a reflector and tried imitate the sunlight. The flashlight was only at low power and only intended as a supportive light for the reflected sunlight. all with Canon 5D MKII, Elmarit R 60mm macro+Leica Apo 2x converter
