Showing results for tags 'leicaq sf40 flash'.
Found 1 result
  1. Hi-- n I have a Leica Q and a SF40 as flash. I used it regularly and without any problem up to a few weeks ago: without any changes on the settings, the camera started shoot photos with Flash underexposed. It's like the flash is out of sync or not working properly. All the photos are dar even if the flash shoot. I tried different setting but still same results. I also tried to reset to factory default the camera, without any result. I recorded a video with default settings and all in A. I will meet a friend of mine with the same camera and flash in a few week to test if the problem is in the flash or the camera. In the meantime, do you have any good suggestions? Is someone having my same experience? Thank you so much Francesco Video of the problem https://www.dropbox.com/s/1gdvx922pkbyhas/IMG_5204.MOV?dl=0
