Showing results for tags 'importing sl2 profiles'.
Found 1 result
  1. I’m current SL2 owner and very recently received my SL2-S. I’ve tried to import my SL2 profiles into SL2-s but on every occasion I get an “import failed” indication. I’ve repeated the process with multiple SD cards with same result. I assumed that being that only difference between the cameras is the sensor resolution that sharing profiles would be pretty straightforward. I spent a lot of time creating multiple profiles for different shooting situations so was hoping to avoid having to go through the entire process all over again on SL2-s Would appreciate guidance from anyone who has figured out how to accomplish this task. Alternately please let me know if what I’m attempting to do simply can’t be done. Thanks.
