Showing results for tags 'flash synch speed'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 1 result
  1. I plan to use an external flash on my D-Lux 5. What is the flash synch speed of this camera? I do have the Leica SF 24D (which I use primarily on my M9) and Olympus S20 flash; both of which are small enough to sit comfortably on the D-Lux 5. Since acquiring the SF 24D, the Olympus S20 has been relegated to the the drawer, but it is still a very competent little flash! Both flashes will be used in automatic or manual mode only. Obviously TTL mode on the SF 24D will not work on the the D-Lux 5.
