Showing results for tags 'aperture setting'.
Found 1 result
  1. I have just started using my first T model fitted with a 45mm Sigma L mount autofocus DGDN f/2.8 lens. Now I normally use Aperture Priority setting, which can indeed be controlled from the T’s body using the relevant adjusting dial. But the lens also has an aperture control ring, so how do I transfer aperture control to the ring around the lens instead of the top dial.
Γ—
Γ—
