Showing results for tags 'aperture fast lens'.
Found 1 result
  1. Advice please, I have a Leicaflex. I am under the impression that 3 cam lenses (except 24 mm ) will work with it. I find that on later (but non rom ) lenses the aperture ring is stiff as it rubs against the camera. I tried a 1.4 85 and it was hard to turn the aperture ring, like wise a 3 cam 1.4 50mm. Put on a SL2 battery cover didn't help No problem with my early generation 50m cron. Am I doing something wrong? So the question is there a 1.4 lens for the Leicaflex I can use without this sticky aperture problem In advance thanks Adam
Γ—
Γ—
