Showing results for tags 'M240 battery bp scl2 charger'.
Found 1 result
  1. Has anyone measured the charging profile (Charging Current and Battery Voltage vs Time) of the Leica BP-SCL2 Lithium-Ion Battery Pack (7.4V, 1800 mAh) in the supplied Leica charger? I could do it but don't mind making use of someone else's measurements. Ideal would be from discharge state (5-10%) to full 100% charge of a battery in good condition using instruments of 0.1% accuracy. The information is of use to me in ascertaining the proper operation or not of other chargers available for the job. Thanks, Harry.
