Showing results for tags 'M10 high ISO vs Leica Q'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 1 result
  1. Guest
    High ISO - M10 vs Q
    When playing with my new M10 last night after installing firmware 2.4.5.0, I decided that I would compare the M10 with my Q in low light. I was stunned at the difference (and needed a whisky afterwards!). With a 28mm Summicron V2 on my M10, and both cameras set at F/2 and ISO 1600, there was a very marked difference in shutter speeds when taking photos of the same subject (plain carpet & backlit curtains) in low light. As one example with auto shutter speeds, the Q was 1/60 and the M10 was 1/5. The other 'test' shots produced the same magnitude of difference. I know ISO is a standard open to varying interpretations, and f/2 on one camera might be marginally different to f/2 on another camera, but I expected the shutter speeds to be broadly similar. Do I have a camera or photographer issue or have others experienced the same when comparing the M10 with other cameras?
