Showing results for tags '50 mm dual range'.
Found 1 result
  1. Hello Leica users, i would like to know if the Leica 50mm dual range with goggles will function on the Leica M11. This is an unmodified sample lens. is there any risk of damaging the body while attaching the lens to the body? I know that previous M’s like M10 will give problems. I read that if you want to use the close focus option on the M11 you have to unmount the lens, then put the goggles on and then mount the lens again to the body to use the close focus range in combination with the Visoflex 2. Is this correct? I also read somewhere that you can attach the lens on the M11 without problems because the mount is different from the other digital M bodys. Again is this correct? Many thanks in advance, greetings and good light, Klassika.
Γ—
Γ—
