Showing results for tags '100mm apo'.
These 3 Pictures were all taken with a M240 and my beloved 100mm APO-Macro-Elmarit-R (& R-M Adapter). This was My first motorcycle. Till this day, my passion for old italian motorcycles grows strong. This little firestarter sparked my livelong joy for thechnical (master)pieces, that leave you with a strong emotional bond. Ducati& Leica have a similar user experience: First, everybody tells you how outdated and expensive they are. Secondly, they will name some much cheaper Japanese alternative, that has better specs and newer tec. Third, when you finally drive/use it, u can never stop thinking about it. Forth, you will make some expensive& not so rational purchases. Fifth, you will enjoy using them and annoy/delight people with your passion. Sixth, they will eventually spoil you for other Brands& user experiences. If I look back, I would to it over and over again, because specs and numbers will never replicate the delight of owning& using one of these "imperfect-perfect" masterpieces. Things don't have to be perfect, to be perfect for yourself. You do not want to use it because it is perfect. You want to use it, because it isn't.
