sandymc Posted November 12, 2009 Share #1 Posted November 12, 2009 Advertisement (gone after registration) CornerFix 1.3.0.3 is now available. This version enhances CornerFix's ability to correct for lens/camera combinations that exhibit extreme forms of optical de-centering and/or asymmetry, leading to "red edges". Broadly speaking, V1.3.0.3 is V1.3.0.2 on steroids as regards its ability to deal with asymmetry. A note on compatibility: The new version will still load profiles from previous versions of CornerFix, right back to the first CornerFix ever released. However, in order to get the benefits of the new algorithm, you must regenerate your profiles using the new version. Using a previous profile on the new version of CornerFix will work fine, but will have exactly the same result as previous versions of CornerFix. The new version can be downloaded here: CornerFix | Get CornerFix at SourceForge.net Enjoy Sandy Link to post Share on other sites More sharing options...
Advertisement Posted November 12, 2009 Posted November 12, 2009 Hi sandymc, Take a look here CornerFix 1.3.0.3 available for download . I'm sure you'll find what you were looking for!
Ario Arioldi Posted November 12, 2009 Share #2 Posted November 12, 2009 Sandy, with this new release I've beeen able eventually to create a perfect profile for my CV15, which so far I coud not manage. Thanks a lot. Cheers, Ario Link to post Share on other sites More sharing options...
Ario Arioldi Posted November 12, 2009 Share #3 Posted November 12, 2009 Just to show the result I'm attaching the file used to make the profile and the same file corrected with the profile. Cheers, Ario Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/103509-cornerfix-1303-available-for-download/?do=findComment&comment=1113898'>More sharing options...
sandymc Posted November 12, 2009 Author Share #4 Posted November 12, 2009 Cool! Sandy Link to post Share on other sites More sharing options...
blatent liar Posted November 12, 2009 Share #5 Posted November 12, 2009 Ario I use the CV 15 a lot, and noticed your post. Amazing, and the Vignetting is gone as well as the Magenta. Can you let me know how you arrived at such a great remedy. I just received a new M9, and the right side of the image is quite Magenta in many shots. Cheers Max Link to post Share on other sites More sharing options...
EricC Posted November 12, 2009 Share #6 Posted November 12, 2009 Many thanks once again Sandy. Link to post Share on other sites More sharing options...
Ario Arioldi Posted November 12, 2009 Share #7 Posted November 12, 2009 Advertisement (gone after registration) Ario I use the CV 15 a lot, and noticed your post. Amazing, and the Vignetting is gone as well as the Magenta. Can you let me know how you arrived at such a great remedy. I just received a new M9, and the right side of the image is quite Magenta in many shots. Cheers Max Nothing special. The latest version of CornerFix did it. With the previous version I could manage to build reasonably good profiles for other lenses but never fort my CV15. As always I have used an house made diffuser, overexpoising +2, bidirectional correction enabled. Sandy did something special with CornerFix 1.3.0.3. Cheers, Ario Link to post Share on other sites More sharing options...
john bartlett Posted March 7, 2010 Share #8 Posted March 7, 2010 I have used Cornerfix 1.3.0.5 to create a lens/camera profile for my CV15 which has effectively eliminated the magenta fringe and corrected the vignetting.. The profile was created by photographing a white card with + 2 stops exposure from meter reading but checking the histogram to be sure there is no question of over exposure ("burnt highlight"). I checked that the illumination on the card was even with a spot meter. There is a slight difference between profiles for F4 and F16. For practical purposes a profile made with an aperture of F8 seems sufficient. Thanks to Sandy John Link to post Share on other sites More sharing options...
Jerry_R Posted March 7, 2010 Share #9 Posted March 7, 2010 I think max. aperture that makes sense for such focal is anyway 5.6 or 8. Doesn't it? Could someone advice how to make this photo for calibration equally lit in home environment? Distance to card, wall must be short - du to wide angle. Then I have difficulties with this equal lit. Flash is not suggested I read. Link to post Share on other sites More sharing options...
