mountainboy Posted May 6, 2007 Share #1 Â Posted May 6, 2007 Advertisement (gone after registration) Sorry to be asking this question but I have tried to follow instruction, but they don't seem to work. I have a mac. My files are RAW files, so of the order of 50Mb. How do I get them into a size to upload them to the site? I think I can manage it from there- I hope. Link to post Share on other sites More sharing options...
Advertisement Posted May 6, 2007 Posted May 6, 2007 Hi mountainboy, Take a look here help with uploading photos. I'm sure you'll find what you were looking for!
andybarton Posted May 6, 2007 Share #2  Posted May 6, 2007 Hi David  You need to convert the RAW files to jpgs, make sure that they are no bigger than 930 pixels either side and no more than around 235 kb.  Then, use the buttons on the posts to upload the images direct to this server.  This thread will help too  http://www.leica-camera-user.com/customer-forum/2341-posting-multiple-images-threads.html  Good luck! Link to post Share on other sites More sharing options...
spylaw4 Posted May 6, 2007 Share #3 Â Posted May 6, 2007 See also the Announcement tip at the head of this sub-forum! Link to post Share on other sites More sharing options...
mountainboy Posted May 6, 2007 Author Share #4  Posted May 6, 2007 Hi David You need to convert the RAW files to jpgs, make sure that they are no bigger than 930 pixels either side and no more than around 235 kb.  Then, use the buttons on the posts to upload the images direct to this server.  This thread will help too  http://www.leica-camera-user.com/customer-forum/2341-posting-multiple-images-threads.html  Good luck!   I use photoshop elements I can't seem to save it as a JPEG. There is an option to save the file as JPEG 2000, but the file size remains the same. How do I resize the file to the size suggested? Link to post Share on other sites More sharing options...
andybarton Posted May 6, 2007 Share #5  Posted May 6, 2007 Firstly you need to resize the image - there should be something under the Edit menu  Set the dpi to 72 and the image size to about 800 max  You also need to make sure that the Image is 8-bit colour depth (if Elements uses 16 bit files - I don't know, it's years since I used it). An option to do this will also probably be under the Edit menu, or one of its sub-menus.  Does Elements have a "Save for web" option under the file menu? If so, this will allow you to resize and save as a jpg of the correct file size all in one window Link to post Share on other sites More sharing options...
mountainboy Posted May 6, 2007 Author Share #6 Â Posted May 6, 2007 Thanks I'll try to upload it for comment Link to post Share on other sites More sharing options...
