humidity
E.M
Hey all , I have been worrying a lot lately about humidity. I have about 70 to 80 % humidity in my appartment , and when I open the window an hour or so it declines to 60 - 64. But after that it rapidly increases again to 70 and more.
I would like an electrical device to dry the air during these winter-months, my room is about 4x5 meters. Any of you have exerience with this , would appreciate advice on brand , noise , expenditure ,cost etc.
Thanks a lot !
Etienne Michiels
x
I use a GE brand dehumidifier that does a wonderful job in the summer months for me which usually gets to around 65% (+/- 5% on average). I use it to knock the humidity down to around 35% - 40% (the limit is 35%).
Noise is only an issue if I'm on the phone because I keep mine close to where my workstation is. Simple push of the button takes care of that, though. Otherwise, it does not bother me.
One can set it up in a fixed location so that a tube drains the water outside. I like to keep it portable so it means emptying the bucket. Usually a daily thing for me to do on the days when it's 60% or more.
I've owned mine for about 3 years and it has not given me any trouble. The current version of what I use is here:
GE® Dehumidifier | AHR40LM | GE Appliances
Hi Etienne,
Earlier this year I spent some time in Lima, Peru with my brother. He lives very near the sea front and the humidity is at times quite astonishing - he told me that when he first moved there he noticed mould growing on clothing within a very short space of time!
He doesn't use (or at least didn't) use a de-humidifier, instead he had tubs containing what I believe to be some sort of desiccant placed in each of his cupboards. They seemed quite effective and I know they were relatively inexpensive.
During my time there I kept all my gear in ziploc bags with silica gel packs whilst I was not using it.
If you're interested in knowing what these tubs were called/what they contained I can certainly ask him.
Hi Etienne,
Too much humidity can give problems as mushrooms in optics and the electronic of cameras also does not like humidity !
...and you have this on your lens :
http://www.summilux.net/forums/viewtopic.php?t=722&postdays=0&postorder=asc&highlight=champignons+optiques&start=120
Thanks a lot !
Etienne Michiels
You really need to create a draft in your appartement because high humidity is bad for the health too. Bad air quality is a source of many health problems...
