Printers
tompkins135
Hi,
I haven't been around for a while, used to be BrianT.
Seriously considering adding an M8 as back up for my Digilux 2, or might wait for Photokina. Only thing I was wondering, are inkjet printers capable of putting down the sort of resolution one obtains with the current generation of printers. In the old days the final outcome no matter what taking lens was used was the enlarging lens. Is there still some sort of tie up only I use an Epson R2400 which is perhaps three years old could it keep up with a F/F Canon fitted with R type lenses for instance, or an M8 with the latest lenses?
Cheers,
Brian
I do not know what you are up to. To my opinion, it would be rather useless to match the resolution of any modern digital camera by an output device, because colour depth is only simulated by (frequency modulated) screen dots. Unfortunately, I do not find proper links to quote the two relevant research articles on this subject, which I remember to have read some years ago. The first was of Prof. Schlaepfer, UGRA. The second one I can link here at least in German: http://www.fogra.org/products-de/download/SoDruck7.pdf
lm
Hi,
Cheers,
Brian
Speaking of the top printers around, the output quality is more affected by your workflow, in other words what you feed them, than by the actual limits your printer might have. Your enlarger lens is nowadays your software and your actual mastering of it.
The latest crop of the Epson top printers, the ones using the UltraChrome K3 pigment inks, are some of the best solutions you can have today for any use, either personal or pro, and, if I'm not wrong, your R2400 is one of them. All of them are able to print the M8 pictures at their very best (and not only the M8 ones of course).
Nice thought of an M8 as a backup to a Digilux 2 ... :-)
Best.
Actually what I am saying is this. Back in the old days the detail/ resolution contained in the final print was controlled basically by three things. The resolution of the taking lens, the film and finally the enlarging lens. Ultimately it didn't matter re the first two stages the enlarging lens was the controlling factor. The best taking lens could only be as good as the enlarging lens.
So my question is and I think the answer could be scientifically proven. Do current top end printers match the output from top end digital cameras or are the lagging behind the recent developments in capture?
For instance the Epson r 2400 was introduced about 2.5 years ago when for instance the Nikon D2 was considered amongst the best. Since then we have seen the D2x, a higher resolution version and now the D3. The enlarger , sorry, the printer has remained the same.
Hence my question.You see back again in the dark ages enlargers for many were considered a bit like Cinderella, I just wondered if the tradition was being carried on.
Simple answers on a post card please.:)
Brian.
