Guest Posted January 5, 2008 Share #1 Posted January 5, 2008 Advertisement (gone after registration) In Capture 1 LE the camera profile had to be selected ie Leica M8 /IR .I can not find in Capture One 4 where to select my Camera profile.I apreshiate thet the answer is probablyvery obvious but i can not find it.Probably an age thing? Brian Link to post Share on other sites More sharing options...
Advertisement Posted January 5, 2008 Posted January 5, 2008 Hi Guest, Take a look here Capture One 4. I'm sure you'll find what you were looking for!
MitchoIankov Posted January 12, 2008 Share #2 Posted January 12, 2008 Brian, I was also annoyed that there is no way (was in 3.7) to set the default ICC Profile. I have found a workaround. Here are the steps Go to folder C:\Program Files\Phase One\Capture One 4\Color Profiles\DSLR\ close Capture One rename LeicaM8-Generic.ICC to LeicaM8-Generic-No-Filter.ICC copy LeicaM8-Generic UV-IR.ICC to LeicaM8-Generic.ICC Now when you start CaptureOne it still uses Generic ICC as default but it has the definitions of the profile with the filter. In the event you need the profile with no filter just manually select LeicaM8-Generic-No-Filter . To prove that it works change between LeicaM8-Generic and LeicaM8-Generic UV-IR and you should see no difference (because the files are the same just the names are different). Seems to work on my PC (Windows Vista). Cheers Link to post Share on other sites More sharing options...
delander † Posted January 13, 2008 Share #3 Posted January 13, 2008 Thanks Mitcho, that is a very useful tip, I have far more images taken with the filters than without, saves a lot of that copying and pasting the profile. I like much of the new C1 v4 but simply fail to under the rationale behind Phase One's removal of features that were in ver 3.7 LE. Just need now to have a method of controlling the placement of Capture One folders everywhere, Jeff Link to post Share on other sites More sharing options...
Max Alfy Posted January 13, 2008 Share #4 Posted January 13, 2008 Bravo Micho! Your tip works 100% on my WinXP. Any other tips? Max Link to post Share on other sites More sharing options...
Guest Posted January 14, 2008 Share #5 Posted January 14, 2008 Hello Mitcho Thank you very much for your reply. Regards Brian Link to post Share on other sites More sharing options...
