yann Posted October 2, 2011 Share #1 Posted October 2, 2011 Advertisement (gone after registration) Hi, I read in older threads that only the Leica UV filter will fit with the lens hood. What about ND filters? I'm looking for feedback from users who have been able to use an ND filters (0.6 or 0.9) with the lens hood. Thanks! Link to post Share on other sites More sharing options...
Advertisement Posted October 2, 2011 Posted October 2, 2011 Hi yann, Take a look here ND filter for 35mm Summilux v2. I'm sure you'll find what you were looking for!
matlep Posted October 2, 2011 Share #2 Posted October 2, 2011 I use B+W ND-Filters on my Summilux. Actually, funny thing is, my first sample of this lens, bought about a year ago, only did take Leica filters. All B+W filters did get the metallic hood a bit jammed when screwed on. I bought another copy of this lens this summer, and on that one all filters fit without the hood jamming. Strange..... Product development perhaps.... Link to post Share on other sites More sharing options...
yann Posted October 3, 2011 Author Share #3 Posted October 3, 2011 Thanks. That's great news! I was a bit concerned that I wouldn't be able to use NDs with this lens (and the hood). My lens is a week old so hopefully, it will behave like yours. Link to post Share on other sites More sharing options...
Fotofanatiker Posted October 3, 2011 Share #4 Posted October 3, 2011 I use both Leica UVa and B+W 46 103 ND 0,9 without any issues... Link to post Share on other sites More sharing options...
Mylek Posted October 3, 2011 Share #5 Posted October 3, 2011 With the 24 Elmarit, i had problem to use a B+W ND filter 0.9 with the hood attached. I remenbered when i was buying the lens the dealer recommend me to buy the Leica UV filter because it was thinner than the B_W. I argued with him but he was right. The B+W might be thinner in thickness but the Leica was had a smaller diameter that allow me to use it without problem with the hood attached. . Link to post Share on other sites More sharing options...
akiralx Posted November 16, 2011 Share #6 Posted November 16, 2011 Is there a discernible loss of sharpness using ND filters on the 35 Summilux FLE? I am thinking of getting a 0.6 B+W for mine. Link to post Share on other sites More sharing options...
nelly Posted November 20, 2011 Share #7 Posted November 20, 2011 Advertisement (gone after registration) I use a Heliopan 0.9 ND filter with my Summilux 35mm FLE and fits perfectly with hood and do not notice any loss in sharpness. I found the 0.9 a better choice for me than the 0.6 I just got back from shooting at Joshua Tree CA with this lens and ND filter and very happy with how my pictures came out. Link to post Share on other sites More sharing options...
brill64 Posted November 21, 2011 Share #8 Posted November 21, 2011 i use mine with a step-up ring and without the hood since i've found my 49 heliopan 0.9nd bought for a tri-elmar to be very good. a lot of people would can me for that, not ideal i suppose but it works Link to post Share on other sites More sharing options...
akiralx Posted January 8, 2012 Share #9 Posted January 8, 2012 Fitting the FLE hood over my new B+W ND filter was a squeeze and when I removed the hood the filter was jammed inside. Managed to force it out, but not easy... Link to post Share on other sites More sharing options...
lars_bergquist Posted January 9, 2012 Share #10 Posted January 9, 2012 I have had the same experience. When I bought an early 35mm Summilux ASPH v.2, the hood was a tight fit even with Leica filters. When I unscrewed the hood, the filter came out too, lodged inside the hood, and had to be pried out. But this past autumn I purchased the 21mm Super-Elmar, which is supposed to use the same 12465 hood, and this slips easily over the same Leica filter. I also tried a B+W F-Pro mounted filter. This too worked well with the late hood, but the early hood would not go over it unless I used more force than I was willing to apply. So it is clear that Leica have quietly altered the inner diameter of the hood. Not that this matters much to me. With lenses with these solid screw-on hoods I prefer to work without a filter. A polariser (in the case of the 35) will require me to remove the hood in any case. It is a different matter with lenses with telescoping hoods, like my 50mm Summilux ASPH, my 90mm Elmarit-M or my Apo-Telyt, where I want the extra protection of a filter. Snap front caps do come off at times. The old man from the Age of the Roll Film Folder (look Ma, no filters! no hoods!) Link to post Share on other sites More sharing options...
akiralx Posted January 9, 2012 Share #11 Posted January 9, 2012 When I bought an early 35mm Summilux ASPH v.2, the hood was a tight fit even with Leica filters. When I unscrewed the hood, the filter came out too, lodged inside the hood, and had to be pried out. But this past autumn I purchased the 21mm Super-Elmar, which is supposed to use the same 12465 hood, and this slips easily over the same Leica filter. Yes - I have the 24 f/3.8 as well as the 35 ASPH FLE and their hoods seem identical and interchangeable (I have swapped them over without difficulty) - but they have slightly different serial numbers (one digit different I think)... strange. Link to post Share on other sites More sharing options...
lars_bergquist Posted January 10, 2012 Share #12 Posted January 10, 2012 Yes - I have the 24 f/3.8 as well as the 35 ASPH FLE and their hoods seem identical and interchangeable (I have swapped them over without difficulty) - but they have slightly different serial numbers (one digit different I think)... strange. I think that if you compare them directly, the hoods will be seen to be of different depth. So they are not identical, but they share the same thread dimansions. Nothing mysterious about that. L.B. Link to post Share on other sites More sharing options...
christer Posted January 10, 2012 Share #13 Posted January 10, 2012 Even leaving the "thin" filters aside, not all B+W filters have the same dimensions even if the diameter and the filter factor are the same. I bought a filter with "nano" treated surface, which is the top grade among the B+W filters, for my Sony Nex 5n short kit zoom lens but was unable to fit the hood when the filter was mounted. So I had to downgrade to the second best B+W filter and then there was no problem with the hood. BTW the people at B+W were very helpful to diagnose the problem and arrange for an exchange. Link to post Share on other sites More sharing options...
