tomas Posted January 28, 2013 Share #1 Posted January 28, 2013 Advertisement (gone after registration) hello, would anyone have any suggestions on non-leica camera bodies to use with leica d 4/3rds lenses (14-50/2.8 + 14-150/3.5)? my understanding from perusing 10 pages of old posts is that it's probably best to stay with 4/3rds camera bodies, as opposed to using the d lenses on micro 4/3rd bodies. thanks. Link to post Share on other sites More sharing options...
Advertisement Posted January 28, 2013 Posted January 28, 2013 Hi tomas, Take a look here Best Non-Leica Body To Use With Leica D Lenses. I'm sure you'll find what you were looking for!
hpu Posted January 28, 2013 Share #2 Posted January 28, 2013 Suggest indeed that you stick with 4/3 rds, like Olymous E series. Good luck. Link to post Share on other sites More sharing options...
jrethorst Posted January 29, 2013 Share #3 Posted January 29, 2013 I'd suggest the Olympus E too. The in-body stabilization might work well with the Leica 25mm 1.4, a well-reviewed lens that doesn't have in-lens stabilization. That lens plus the 14-150 would be my choice of kit. Link to post Share on other sites More sharing options...
lemalk Posted January 30, 2013 Share #4 Posted January 30, 2013 The 14-50 will work on any of the Micro 4/3rds bodies that Olympus has released, albeit with a 4/3rd -> m4/3rds adapter - and will focus more slowly than on a native 4/3rds body. The 14-150 will focus just as quickly and accurately on any of the Olympus or Panasonic m43rds body because the lens has contrast detection auto focus (CDAF) enabled. I use my original, full size Leica D 25mm 1.4 and 14-50mm 2.8 D-Vario Elmarit on an Olympus Pen E-P2 and have more accurate focus than on my Leica Digilux 3 4/3rds body. The Lumix bodies tend to be pickier and more problematic with 'legacy' 4/3rds lenses than the Olympus OM-D, or Digital Pens. Hope that helps. Link to post Share on other sites More sharing options...
tomas Posted January 30, 2013 Author Share #5 Posted January 30, 2013 thank you for your suggestions... it seems like olympus is the way to go...and i note that olympus recently released a new 4/3rds body, the "e-5"... in terms of picture quality, and assuming that one opts for the micro 4/3rds route, would you say the results with olympus micro bodies are comparable with the results of the original leica digilux 3? thanks again... Link to post Share on other sites More sharing options...
ezc203 Posted January 31, 2013 Share #6 Posted January 31, 2013 After I sold my M8 (and before I picked up my M9) I played around with an Olympus OM-D E-M5, and in my opinion it's the best m4/3 camera out there, at least for me. Image quality was superb and I paired it with some Leica DG prime lenses. The 25mm Leica D Summilux is really superb. Some sampel images here from my blog: asphericalperspective. • Park here. asphericalperspective. • Bell & Ross The ISO range is great on the OM-D E-M5 and the resolution is pretty decent too. I'm not a huge fan of how the colors are rendered in the JPEGs, but if you shoot RAW you'll have better control of those things in post. Overall, I would highly recommend this particular Olympus. Link to post Share on other sites More sharing options...
jrethorst Posted February 2, 2013 Share #7 Posted February 2, 2013 Advertisement (gone after registration) How much functionality do you lose with an adaptor to use 4/3 lenses on m4/3 bodies? Panasonic makes the Leica-D 25mm 1.4 for both 4/3 and m4/3, but the D 50-150 zoom seems to be 4/3 only. Link to post Share on other sites More sharing options...
JDFlood Posted February 14, 2013 Share #8 Posted February 14, 2013 Consider Fuji XE-1 or pro. JD Link to post Share on other sites More sharing options...
colmac Posted February 28, 2013 Share #9 Posted February 28, 2013 Eddie, Any idea where current Panasonic Leica DG lenses like the DG MACRO-ELMARIT 45mm f2.8 ASPH and DG Summilux 25 mm f1.4 ASPH are manufactured. Japan or China? Maybe moving to Burma soon... Colmac Link to post Share on other sites More sharing options...
bjmike Posted April 27, 2013 Share #10 Posted April 27, 2013 The original question on this thread was about Leica D lenses. Those are the ones manufactured by Panasonic under Leica supervision & w/ Leica specs (whatever those two statements mean). While they work quite well w/ the Oly MFT cameras, they were designed specifically for the Panny GF, GX, G & GH cameras. I have both the Leica D 25mm (~50mm) and Leica D 45mm (~90mm) and am currently using them on a Panny GX1. Since I'm traveling and don't have that kit w/ me, I can't remember whether they each have built-in OIS, but using that lens-based OIS with Oly's in-body IS might (IMO, will) be a bit of overkill and possible incompatibility. Easily fixed by turning either system off (or both, for that matter). Either way, the Oly OMD & Panny G, GX, or GH will work well w/ the Leica D lenses. I've found them to superb lenses, altho not as physically robust as Leica M lenses. FWIW! Link to post Share on other sites More sharing options...
dhsimmonds Posted May 5, 2013 Share #11 Posted May 5, 2013 The advantages of the OM-D E-M5 over the Panasonic m4/3rds is that the Oly has inbuilt superb image stabilisation (IBIS) allowing use of this facility for ANY lens used on the OM-D body. Add the advanced Sony sensor with it's high ISO capability and wide dynamic range, all in a small body, it becomes an awesome little tool. The Leica D lenses work very well on this body and it was hinted by a Panasonic UK manager at a recent Fellowship lecture that the m4/3rds Leica DG range is likely to be extended fairly soon. At the same talk, the myths and rumours surrounding the Leica/Panasonic liason were finally debunked. The Leica lenses are made in the same factory as their G lenses but Leica approve and frequently modify design and tolerance specifications for their lenses. In addition Leica operate a strict QC regime for the Leica DG lenses. It is all reflected in the Panasonic pricing structure. It goes without saying that the Panasonic G and X lenses also benefit from all this lens expertise sloshing around their factory. The Leica DG lenses undoubtedly render a more "artistic" image with much smoother bokeh than is generally so with other Pany lenses. Oly Zuiko mFT lenses have always enjoyed an excellent reputation for sharpness and quaility of image rendering. In fact, I suppose that we are spoiled for choice in the mFT world! Link to post Share on other sites More sharing options...
dkCambridgeshire Posted May 5, 2013 Share #12 Posted May 5, 2013 hello, would anyone have any suggestions on non-leica camera bodies to use with leica d 4/3rds lenses (14-50/2.8 + 14-150/3.5)? my understanding from perusing 10 pages of old posts is that it's probably best to stay with 4/3rds camera bodies, as opposed to using the d lenses on micro 4/3rd bodies. thanks. Lot of bias in this thread towards micro four thirds bodies - but regular 4/3 bodies should not be overlooked especially the fast focus Olympus E-5 which has image stabilisation and an optical reflex viewfinder which is far superior to any M4/3 mirrorless camera. The Leica D Summilux 25/1.4, Leica D Vario Elmarit 14-50mm f2.5-3.5 and Leica D Vario Elmar 14-150mm f3.5/5.6 lenses can all be used with all Olympus 4/3 cameras. dunk Link to post Share on other sites More sharing options...
jrethorst Posted May 6, 2013 Share #13 Posted May 6, 2013 the m4/3rds Leica DG range is likely to be extended fairly soon. I'm very glad to hear that. Link to post Share on other sites More sharing options...
bjmike Posted May 18, 2013 Share #14 Posted May 18, 2013 In-body OIS v. in-lens OIS isn't inherently superior. It depends on much more than that, including what focal length the lens is, what you are doing with it (still or video), as well as the specific technology (virtually every manufacturer being a bit different). About the only inherent advantages are that the lenses w/o internal OIS are often (and not always) cheaper and, secondly, that in-body OIS is more versatile (in that you always have it available, regardless of the lens you may be using. Link to post Share on other sites More sharing options...
