StS Posted May 21, 2007 Share #1 Posted May 21, 2007 Advertisement (gone after registration) Hello all, someone just mentioned the advance lever of my double stroke M3 is not fully spring loaded. After letting go the lever, the spring will pull it back to the position shown rather than to the shutter dial. Funnily I never recognized this point I just got used go guide the lever back with my thumb, I thought it was meant to be this way. Just out of interest, I wouldn't bother to change it - does someone know, whether the spring of the advance lever of a DS should pull it back to the shutter dial? Quote Link to post Share on other sites More sharing options...
Advertisement Posted May 21, 2007 Posted May 21, 2007 Hi StS, Take a look here M3 DS - is the advance lever spring loaded?. I'm sure you'll find what you were looking for!
doubice Posted May 21, 2007 Share #2 Posted May 21, 2007 Stefan, This indeed is the correct 'stand-off' position of the DS version. Allows you to shoot with your right eye and advance the film without taking the camera from your face. On the single stroke versions the lever sat closer to the body whe returned from winding. Also - yours must be a relatively early DS. The early advance levers were shorter, designed slightly differently and did stand off a little further. If you changed your advance lever for one from the current MP, the 'stand-off' position would be closer to the body. To make the long story short - there is nothing wrong with your M3. Best, Jan Quote Link to post Share on other sites More sharing options...
StS Posted May 22, 2007 Author Share #3 Posted May 22, 2007 Hello Jan, thank you very much for your advice. Cheers Stefan Quote Link to post Share on other sites More sharing options...
