Developer Temperature
Annibale G.
Hi,
I was just asking mself why some developer mainly the Kodak TMax use as standard deleveloping time 24°C instead of the classic 20°C. What are the differences?
Can I use lower temperature? 22°C or 20°C
How can I find the others developing time at different temperatures?
Thanks
Annibale
Yes you can but the best preformance of the Tmax developer with Tmax films is on 24 degrees C.
Some other developers are also working on a higher temperature like the CG512/Rollei Low Speed developer: Also 24 degrees C.
Most developers are working best on 20 degrees C. Rodinal even better on a lower temperature: 18 degrees C. because with slow agitation and close around 18 degrees C. you will have less grain with this Para-Amino Phenol developer.
Always make a time correction according the Ilford/Harman temperature correction table. Within the range of 18-24 degrees C you will normally succeed without too much deviations. Some components are inactive under 18 degrees C and normally above 24 degrees C. the developing time can be too short for a reproducible result and the emulsion is getting pretty soft over 24 degrees C. so that means you have to use a hardener then.
Best regards,
Robert
