Collapsible Summicron and Type I Rigid Summicron Comparison Shots
brianv
This is an informal lens test between two of my Favorite lenses, A late Collapsible Summicron that I CLA'd myself, and a 1957 Type I Rigid Summicron that I had professionally CLA'd. Both are very clean, and I think representative of their type.
This is not a test for absolute resolution of the lenses, but more of the rendition of the two pieces. These are as they came off of the scanner, and re-sized using photoshop. No post-scan processing for contrast or color balance.
First up: The Collapsible Summicron wide-open at F2.
x
And the Type I Rigid, wide-open:
The Collapsible Summicron at F2 and at F4:
Type I Rigid Wide-Open at F2:
One more with the Collapsible Summicron, wide-open with tight crop for center detail:
Just one more Comparison! Not on the same roll, this is with a 1935 Uncoated Summar at F2:
YES! You can make any modern film look like Kodachrome 10! Can anyone doubt that there is a special quality to these lenses, designed WITHOUT the aid of a computer?
Thanks for sharing. I have just adquired the collapsible and the type I (Dual Range with gogles) and I'm in the process of using them. I expect to get as good results as your photos when I'm done using them.
Thank you for this interesting test. Yes, the Summar is a beauty. Unfortunately, very sensbible to flare. But a good coated Summar could do a very good job indeed.
However, the judgement of lenses in black and white is quite different.
This is what I did with the 50mm collapsible Summicron whide open:
And this is the rigid, but at F4:
  • 1 year later...
  • 3 months later...
  • 6 years later...
Wow like a Paint!!  Contrast is amazing, light is fluid, and the back scene is blowing my eyes!!!!  There is something about the way they used to built lens it is a good example for the art of the craftsmanship....a bit different from the today mass production made in China !
