pinetar Posted July 18, 2006 Share #1 Â Posted July 18, 2006 Advertisement (gone after registration) I was to use the d-lux for qtvr and need the nodal point setting if anyone knows it. Â thanks Link to post Share on other sites More sharing options...
ho_co Posted July 18, 2006 Share #2 Â Posted July 18, 2006 I can't answer the question. Â You might end up needing to speak with the lens designer if possible. Â You should probably also specify both focal length and which nodal point (front or rear) since I suppose the two move with varying zoom. The nodal points would also move a very small amount depending on the focus point, but I'm sure you could neglect that. Â For simplicity you might just choose the front plane of the body, assuming that it is near the rear nodal point, and call it done. Â With luck there's someone on the forum who'll be so upset by this non-answer that he'll jump in with what you need. Â Good luck! Â --HC Link to post Share on other sites More sharing options...
ddh Posted July 18, 2006 Share #3  Posted July 18, 2006 Gary, there are numerous websites that explain in detail how to determine the nodal point of a given lens. (Just google nodal point lens) For example this one: http://www.vrphotography.com/data/pages/techtutorials/technotes/nodalptalign-tn.html  Hope this helps. Link to post Share on other sites More sharing options...
john_f Posted July 18, 2006 Share #4 Â Posted July 18, 2006 Daniel, Â Very good web site! Â Â Â Gary, Â I don't know where the nodal points of the DC-Vario-Summicron 7-22.5mm zoom lens might be located, but I think I know who might be able to help you: Andrew Nemeth of http://www.nemeng.com/. Andrew is an avid Leica enthusiast (like all of us) and is a member of this Leica forum. And he does quite a lot of (extraordinary!) QuickTime VR. If anyone can help you, it's him. Â Good luck! Â John F. Link to post Share on other sites More sharing options...
pinetar Posted July 18, 2006 Author Share #5 Â Posted July 18, 2006 Thanks for the tips. Â gary Link to post Share on other sites More sharing options...
