wda Posted September 14, 2009 Share #1 Posted September 14, 2009 Advertisement (gone after registration) This message is intended to be a warning following my realization that my fairly new magnifier nearly disappeared. It appears that the pin in the anchor ring on the lens barrel became detached, unbeknown to me. It probably happened during a rare removal to enable a wide angle lens to be used. Fortunately I had stowed the lens, still with attachment cord, into its little leather case. It was only when I went to refit the magnifier that I realize the cord was no longer attached. Worse, the rear locking ring was also missing. Had I left it dangling on the camera I would almost certainly have lost the whole unit. Has anyone else suffered a similar experience? Thanks to Frank Foster, from whom I purchased the item, he contacted Leica for me and I have since returned the item to Leica UK. That was a kindly act in view of his recent retirement. Link to post Share on other sites More sharing options...
Advertisement Posted September 14, 2009 Posted September 14, 2009 Hi wda, Take a look here A faulty 1.4x viewfinder magnifier . I'm sure you'll find what you were looking for!
glenerrolrd Posted September 14, 2009 Share #2 Posted September 14, 2009 This message is intended to be a warning following my realization that my fairly new magnifier nearly disappeared. It appears that the pin in the anchor ring on the lens barrel became detached, unbeknown to me. It probably happened during a rare removal to enable a wide angle lens to be used. Fortunately I had stowed the lens, still with attachment cord, into its little leather case. It was only when I went to refit the magnifier that I realize the cord was no longer attached. Worse, the rear locking ring was also missing. Had I left it dangling on the camera I would almost certainly have lost the whole unit. Has anyone else suffered a similar experience? Thanks to Frank Foster, from whom I purchased the item, he contacted Leica for me and I have since returned the item to Leica UK. That was a kindly act in view of his recent retirement. Had the exact same problem with a 1.25x. Link to post Share on other sites More sharing options...
