wbesz Posted August 23, 2009 Share #1 Posted August 23, 2009 Advertisement (gone after registration) What battery voltage is used in the M6? It seems my M6 is the TTL version (not the classic. Are the batteries different:confused: between these two cameras?The classic seems to use smaller batteries. THank you in advance. William Link to post Share on other sites More sharing options...
Advertisement Posted August 23, 2009 Posted August 23, 2009 Hi wbesz, Take a look here M6 TTL battery. I'm sure you'll find what you were looking for!
lars_bergquist Posted August 23, 2009 Share #2 Posted August 23, 2009 Two stacked 1.5 volt silver oxide batteries type SR-44, or one 3 volt lithium. The old man from the Age of Carbon-Zinc Batteries Link to post Share on other sites More sharing options...
StS Posted August 23, 2009 Share #3 Posted August 23, 2009 The same batteries can be used for the M6 classic. Personally I prefer the lithium batteries (1/3N). One has to live with a hidden disadvantage - they last so long, one probably has forgotten the battery type, when they are finally flat.... I bought two 1/3N batteries, when I bought the camera, the second one has a shelf life until 2017, according to the package... A manual for the M6 classic can be found here: Leica Bruger Information: Leica M6 Classic Manual Stefan Link to post Share on other sites More sharing options...
wbesz Posted August 23, 2009 Author Share #4 Posted August 23, 2009 The same batteries can be used for the M6 classic. Personally I prefer the lithium batteries (1/3N). One has to live with a hidden disadvantage - they last so long, one probably has forgotten the battery type, when they are finally flat.... I bought two 1/3N batteries, when I bought the camera, the second one has a shelf life until 2017, according to the package... A manual for the M6 classic can be found here: Leica Bruger Information: Leica M6 Classic Manual Stefan Stefan, what about M6 TTL? Thanks Thanks guys, but those small batteries only add up to be 3 V (for the M6 classic), I thought perhaps the M6TTL version used more voltage (bigger) cells and would add to be 6volts? Link to post Share on other sites More sharing options...
stunsworth Posted August 23, 2009 Share #5 Posted August 23, 2009 It's the same battery in both cameras. The camera operation is virtually identical between the M6 and M6 TTL. The only manual I've ever had for an M was the one that came with my M8. Link to post Share on other sites More sharing options...
erl Posted August 23, 2009 Share #6 Posted August 23, 2009 Steve, the thumb on your right hand is the 'manual' for the M6 & M6TTL. (Ducks for cover ) Link to post Share on other sites More sharing options...
peter_n Posted August 23, 2009 Share #7 Posted August 23, 2009 Advertisement (gone after registration) CR 1/3N is the full name of the battery. The M7 uses two, all M6s use one. They're quite expensive retail, like at Radio Shack. Get them on the internet, best battery is probably Varta, best value is bulk Sanyo. Shelf life is enormous. Link to post Share on other sites More sharing options...
