maxnoy Posted August 1, 2009 Share #1 Posted August 1, 2009 Advertisement (gone after registration) I noticed an issue with my M6 where the film counter is always lagging by about 7 frames. When I take off the bottom plate, I can see the counter resetting to 7 frames before 0. Of course, it's not hard to figure out where you are in the roll, but I am still wondering whether this is common and if it can be fixed or worked around without a CLA? Thanks, Maksim Link to post Share on other sites More sharing options...
Advertisement Posted August 1, 2009 Posted August 1, 2009 Hi maxnoy, Take a look here M6 Film Counter always 7 frames behind. I'm sure you'll find what you were looking for!
moikle Posted August 1, 2009 Share #2 Posted August 1, 2009 I've got the same problem with my M7. It currently with Leica UK to sort that and other problems. Mike Link to post Share on other sites More sharing options...
Shootist Posted August 2, 2009 Share #3 Posted August 2, 2009 The frame counter wheel is just fixed/attached by one screw, in the center of it. If that screw becomes loose, because it wasn't tighten properly, the counter can and will rotate fairly easily. The only fix is to take the top plate off, reset the wheel, with the bottom plate off that would be 2 frame before zero, and tighten it, applying some blue (removeable) thread locker on the threads, properly. Link to post Share on other sites More sharing options...
rob_x2004 Posted August 2, 2009 Share #4 Posted August 2, 2009 Surpirsed they dont use loctite or something. M6 is getting on a bit but loose screws seems to be a common thread with Solms. My shutter speed dial has fallen off twice, following each trip to solms. Providing I find all the bits I can tighten it adequately. Beats me. Link to post Share on other sites More sharing options...
