mojobebop Posted May 1, 2009 Share #1 Posted May 1, 2009 Advertisement (gone after registration) hello, i was interested in bulk loading for the m7. 1. are there any made which will fit into the m7? if anyone has any info i would greatly appreciate any advice. thanks, rh Link to post Share on other sites More sharing options...
Advertisement Posted May 1, 2009 Posted May 1, 2009 Hi mojobebop, Take a look here film cassettes for m7?. I'm sure you'll find what you were looking for!
pleeson Posted May 1, 2009 Share #2 Posted May 1, 2009 Any standard one will fit, but the metal ones with DX coding are necessary to read ISO automatically. I use Kalt brand. In a related note, the early M7 had a mechanical ISO reader that grabs the film canister so tightly as to make removal very difficult. It can be changed out for the later optical reader, a procedure I'd recommend as it's pretty easy to pull the bulk loading canisters apart. Link to post Share on other sites More sharing options...
mojobebop Posted May 1, 2009 Author Share #3 Posted May 1, 2009 Any standard one will fit, but the metal ones with DX coding are necessary to read ISO automatically.I use Kalt brand. In a related note, the early M7 had a mechanical ISO reader that grabs the film canister so tightly as to make removal very difficult. It can be changed out for the later optical reader, a procedure I'd recommend as it's pretty easy to pull the bulk loading canisters apart. ----- whether mine is old or not i can't determine, as i have not found the serial # listing as you find with m6, & other m's. my m7 is #2784xxx. Link to post Share on other sites More sharing options...
peter_n Posted May 2, 2009 Share #4 Posted May 2, 2009 Mine is close, 2786xxx and it didn't have the optical reader. It is likely yours has the mechanical type, which appear as pins that stick out very slightly into the film chamber. The pic below shows the optical reader together with the added washer on the bottom plate locking mechanism. Link to post Share on other sites More sharing options...
tobey bilek Posted May 2, 2009 Share #5 Posted May 2, 2009 Kalts will fit. Buy a carton of 100 for $60 and they are all clean. The old Leica brass film cassettes which do not use felt will not fit. Therefore my M6`s are the last ones I will buy. BTW, the current plastic ones which I prefer will not work in screw mt, M or R cameras. I get to exposure 10 or 12 and they refuse to feed in any for my many Leica cameras. I have no idea why. Link to post Share on other sites More sharing options...
