tchav Posted April 6, 2009 Share #1 Posted April 6, 2009 Advertisement (gone after registration) When I attach the motor winder to the camera, an incessant beeping noise results when I press the shutter release. What gives? Link to post Share on other sites More sharing options...
Advertisement Posted April 6, 2009 Posted April 6, 2009 Hi tchav, Take a look here R 6.2 with beeping motor drive. I'm sure you'll find what you were looking for!
garyp Posted April 6, 2009 Share #2 Posted April 6, 2009 Check the switch on bottom of drive: it should be set towards the 'single dot'. If it is set to the 'double dot', it indicates double exposure mode and will beep to warn you of that. Link to post Share on other sites More sharing options...
zapp Posted April 8, 2009 Share #3 Posted April 8, 2009 Check the switch on bottom of drive: it should be set towards the 'single dot'.If it is set to the 'double dot', it indicates double exposure mode and will beep to warn you of that. Also put the drive on double dot to rewind the film. I got my winder without instruction manual as well, the double dot finally makes sense. Link to post Share on other sites More sharing options...
