Zeiss 18mm f4 Question
NB23
To the 18mm Zeiss lens owners, I have a question.
My lens' front section (where the aperture ring is) wobbles very slightly. Does your lens have the same behavior? I'm thinking of sending it in for warranty work but just want to make sure.
So far I've had 3 leica lenses unscrew in half in my hands after they started wobbling, but I am not sure the Zeiss lenses have the same construction.
Thanks for the help.
x
No wobble at all. Very strong and straight here.
Nenad, Judging from your experience with 3 Leica lenses coning apart on you, I would send your Zeiss lens for warranty adjustment. Don't wait until it goes out of warranty, part with it while you can (for free). I had that experience once with a 50 Summicron , very sobering. BTW I remember your article in LFI a while back, M7 and Noctilux, phenomenal shots. Good luck, Russell
Thanks Russell!
I have many more new shots. I'll have to upgrade my site, which I haven't touched in more then a year now.
I and many others have seen the "loosening" and wobble you describe with ZM 28mm lenses. It is easily fixed by tightening a retaining ring on the mount (it is probably loose to the touch.
Have a peek, it might solve your problem :)
Kent
Kent
I can't see any retaining ring on the mount. But I'm not sure I understand. Maybe could you post a picture showing it? Greatly appreciated!
