Sticking down the leatherette on an R8 R9 Motor Drive
rick_dykstra
Hi folks. Now that I've got my R8 motor drive working again I'd like to finish the job neatly by sticking the leatherette back on properly. Leica use a thin sheet of double sided adhesive to do this. This adhesive has lost much of its stickiness with all of the work I've been doing.
Does anyone know what this adhesive film is and where it can be bought? Are there any alternative methods/products that have worked well?
Thanks. Rick.
x
Thanks. Rick.
Rick
Just a thought. Is this stuff anything like the double sided Sellotape (or one of several alternative brands) which I use as part of my print mounting process. It's the stuff that you stick down one side, then peel off a backing layer, to leave the other sticky side exposed? I guess you could try using that.
I think you should just use a general purpose impact adhesive - brand names in the UK would be "Bostik" or "Evo-Stik" - apply it sparingly, spread to the edges, let it become tacky and press on, tape it in position overnight.
You could use your wife's credit card to spread the adhesive which would prevent her using it to buy more shoes...
The other thing you could consider is using a rubber based cement like Henzo for sections in between the contact cement, or even just use it without the contact. You will always be able to get it back off.
Your motor drive thread is pretty amazing.
It's been amazingly time consuming! And not just for me. :)
Hopefully there's something in the threads to help others with similar motor drive or battery problems. Like, only go poking around in there if you're prepared to fix what you damage! :D
Thanks for the ideas on adhesives. I have some Henzo glue for sticking prints into acid free albums - I'll give it some thought.
