kodaktrix Posted August 6, 2006 Share #1  Posted August 6, 2006 Advertisement (gone after registration) Good morning from rainy Munich to all the Telyt 6.8/400 users worldwide. Mine seems to be in need for a lubrication maintanance as the focusing unit does no longer run entirely smooth all the way. As I will work on this lens for the first time, I would appreciate advices on what lubricant to use. I personally would go for silicone grease (the one I use on my Nikonos O-rings). Temperatures over here go from -20°C up to +40°C (as we had to experiance this year). Thanks in advance!  Best regards  Oliver Link to post Share on other sites More sharing options...
Advertisement Posted August 6, 2006 Posted August 6, 2006 Hi kodaktrix, Take a look here Need advice on lubricating Telyt 6.8/400. I'm sure you'll find what you were looking for!
telyt Posted August 6, 2006 Share #2 Â Posted August 6, 2006 Silicone can damage lens coatings, be very careful where this stuff goes. Link to post Share on other sites More sharing options...
kodaktrix Posted August 6, 2006 Author Share #3  Posted August 6, 2006 Hello Doug,  my hope was that You would respond. What kind of lubricant do You use on Your Telyts, or do You have them serviced?  Best regards  Oliver Link to post Share on other sites More sharing options...
telyt Posted August 6, 2006 Share #4 Â Posted August 6, 2006 Oliver, I've only had to have the 560mm lens serviced. I had Don Goldberg lubricate it four years ago when it needed some other work done on it. Link to post Share on other sites More sharing options...
