scc Posted January 10, 2010 Share #1 Posted January 10, 2010 Advertisement (gone after registration) Hi all, I've not been able to find a definitive answer despite a search.. Can the hood be used on this lens when a filter is mounted? I've read some reports that the hood will not attach with some filters. Is there a specific filter brand or size that will allow the hood to be mounted? Appreciate any help, Cheers, Stuart Link to post Share on other sites More sharing options...
Advertisement Posted January 10, 2010 Posted January 10, 2010 Hi scc, Take a look here 24mm Elmarit M ASPH owners.. Filter question . I'm sure you'll find what you were looking for!
azzo Posted January 10, 2010 Share #2 Posted January 10, 2010 Hi Stuart, I use a B&W uva filter on my 24 Elmarit. No problem to mount the hood. Link to post Share on other sites More sharing options...
scc Posted January 10, 2010 Author Share #3 Posted January 10, 2010 Thanks azzo, Can you tell me whether it is a slim filter or normal... Do you have the model no? Cheers, Stuart Link to post Share on other sites More sharing options...
azzo Posted January 10, 2010 Share #4 Posted January 10, 2010 Thanks azzo, Can you tell me whether it is a slim filter or normal... Do you have the model no? Cheers, Stuart Normal size, B&W 55 010. Link to post Share on other sites More sharing options...
scc Posted January 10, 2010 Author Share #5 Posted January 10, 2010 Awesome, thank you.. Link to post Share on other sites More sharing options...
azzo Posted January 10, 2010 Share #6 Posted January 10, 2010 You're welcome. Enjoy this wonderful lens. Link to post Share on other sites More sharing options...
holgerf Posted January 10, 2010 Share #7 Posted January 10, 2010 Advertisement (gone after registration) Hi Stuart I’m using the Leica UV/IR filter 55mm, no problem at all (part #13413). Best Holger Link to post Share on other sites More sharing options...
waileong Posted January 10, 2010 Share #8 Posted January 10, 2010 Normal filters fine, no vignetting. But note that with some filters, the hood cannot be mounted, eg thick polarisers. Link to post Share on other sites More sharing options...
wizard Posted January 10, 2010 Share #9 Posted January 10, 2010 I use mine with a B+W UV slimeline filter. Hood fits, too. Andy Link to post Share on other sites More sharing options...
hoppyman Posted January 10, 2010 Share #10 Posted January 10, 2010 Stuart as noted by others, most filters can be mounted and the hood clips over it onto the lens itself. It needs to be not a larger diameter but that should not be a problem. The Leica UV/IR filters are deeper than many standard filters (for example the excellent B+W range) but it definitely fits inside the hood (I've used it). A polariser would not fit, but that is a different situation and you would need to have no hood mounted to allow you to operate the polariser anyway. Link to post Share on other sites More sharing options...
peter_n Posted January 10, 2010 Share #11 Posted January 10, 2010 I use a regular B+W E55 MRC UV filter on mine. Manufacturers product nr. 70216. It is a bit tight but the hood does fit over it. Awesome lens! Link to post Share on other sites More sharing options...
scc Posted January 10, 2010 Author Share #12 Posted January 10, 2010 Thank you all for your replies, good info here. I just purchased the lens recently, although haven't got my hands on it yet. Should be a great pairing with the M9 - I'm excited Link to post Share on other sites More sharing options...
