M8 and Landscapes - workflow and conversion - some thoughts
jonoslack
Hi There
Most of my work involves natural light and landscape - and at this time of year that means very rich evening light and tricky colours (so easy to turn delicate warm light into an over-saturated horror show!).
I've been using Aperture for most of my work for the last 9 months, and I really do like it - at the moment it's not a possibility with the M8 - hopefully there will be support at a later date. In the meantime I needed to find something which worked - my problem has not been purple blacks, but how to make the most of the wonderful (huge) colour gamut the Leica produces.
The first stop was C1 - the default profile is much much too yellow for evening light - I've tried others, and of course one can always fiddle with the White balance (irritating if you felt you'd got it right in camera). The result is cyan skies and a lack of green in foliage.
So - that only really left ACR - unlike some I rather like ACR, but the embedded profile, although better for landscape, has a tendency to pink reds (berries are always a problem , and in this respect the M8 is no different. I tried using the ACR3.6 profile, which seems to work really well for tungsten portraits - but which isn't too good for landscapes either.
In the end I've made some very simple changes to the 'embedded' profile in ACR - simply increasing the red hue by 14, and reducing the saturation a little. That seems to have done the job, and I'm getting nicely saturated colours.
I also tried shooting jpg (I like to shoot jpg if they're good - like the Olympus E1 - it makes me take more care with my exposures). They're attractive - much greener than most of the other converters, but I'm afraid there are signs of tell-tale smearing in foliage, especially grass, it isn't bad, but it's not there in the ACR conversion ; it IS there in the C1 conversion in pine trees - not signifantly, but it is there.
Here are some examples - the first two are taken with the CV15 - what's astonishing about this lens after using it with the R-D1 is that, at f8, I did no vignetting control whatsoever!
These two were taken with the CV Ultron 28mm f1.9:
(it was voigtlander day today!)
I still haven't quite nailed the conversion to sRGB, and these have lost a little of their vibrancy in the conversion and reduction - still, the idea was to have a variety of shots with some different lighting.
I'm completely overjoyed by the quality and detail of these files (the quality of the photographs may be a different issue!)
The camera is a joy to use, and, at least for this kind of work, there is no need to use an IR filter. I just hope that the 'fix' doesn't involve a stronger filter which introduces cyan/magenta shifts across the frame as it did in the Kodak 14n.
It's astonishing reading the bashing that the camera is getting, and then looking at an A2 print of one of these files - it's hard to believe that it's the same camera that they're talking about.
I hope this was of some interest to someone!
Lovely photo's John, looks like around Dorking, Surrey? Why srgb I find it much less accurate than Adobe or colormatch?
Hi David
I only use sRGB for the internet - why? mmm - 'cos I read somewhere that I should, and if you use Adobe, then they look rather flat on most browsers.
Dorking? I don't think so! Dorking is surburban hell on Earth. Those big skyscapes and architecture in Jono's portfolio suggest somewhere like East Anglia (Eastern England).
Hi There
Quite right - Norfolk Suffolk borders - in fact, half taken in Suffolk (first two) half in Norfolk.
Jon -
Very nice work -- I'm glad you persisted so. However, all but the first seem a bit over sharpened.
Hi There
Well, I think it's to taste - I don't do any sharpening in the conversion - maybe there's a little too much on the reduction to web size.
After years with a dSLR, the general sharpness without an AA filter is a bit of culture shock :)
Hi David
Jono, great photographs - thanks. I also resize and SRGB for posting for the same reason! If I shouldn't.....
You had much better weather than I did in Surrey.
Beautiful work Jono. I love the fine detail in these landscape images. I'm also planning on moving to an M8 for landscape work and using CV lenses I already have (same ones you used plus a couple of Heliars and a Nokton). I just hope Leica doesn't modify the firmware/lens coding to the point that 3rd party lenses can't be used to achieve the excellent performance that you have demonstrated with these samples.
Web browsers (none of them) display images very well, and none use Adobe RGB to calculate what they display.
The closest you will get to seeing on a screen using a browser is to use sRGB as your final conversion before posting, but even this looks poor compared to opening a posted jpg in Photoshop, or something that understands colour properly. If Adobe made a web browser capable of displaying what is seen when using Photoshop, they'd make a killing ;)
Some commercial scans only scan to sRGB and lots of information is lost - obviously this is not an issue for M8/DMR users. Scanning at anything less than 16 bit is to lose a lot of data before you have even begun. (I always shoot in Adobe RGB and RAW - it pays to have as much information to hand at the beginning, only dropping info at a later stage.)
When using C1, did you adjust the curves for each of the R/G/B channels individually?
Hi Carl
I'm sure there won't be anything to stop you using other M mount lenses. What has surprised me is how little vignetting there is on the 15 mmCV - The wall to wall sharpness is a new experience for me!
Hi Andy
On the mac, Safari seems to do the best job with these - but I'm afraid it's a 'no win' situation
I did try fiddling with the channels separately in C1, of course that's okay, but I want to find something which works for 'most' shots without special treatment. I love the Aperture workflow as well, so in the end, I'm hoping that they come up with the goods.
Still - these may not be perfect, but they aren't horrid, and that warm light always causes me nightmares (never managed it with the D2x).
It must be a CV kind of day.
Taken with the CV 50/1.5 Nokton today around Noon local time. I'm not blown away by the sharpness but I thought the M8 handled the backlighting well in this shot. Overcast sky; JPG Fine; no manipulations, straight from the camera; ISO set to 320; WB is "Auto."
-g
jono theses are lovely, especially the first one
I think the j holmes dude makes some really great profiles for this sort of thing -- google him, really good for keeping blue skies and green foliage, while retaining colour highlights of berries, flowers etc
but i read somewhere today that a colour guru says we all should all be using the _smallest_ colour space possible (srgb on the m8?) so that no colours are lost during any conversion, even for the web. does anyone have any knowledge about that ?
I usually use eci or prophoto but like you, convert to srgb 2.1 for web (a web-designer friend tells me that is most reliable as most browsers don't colour manage)
dave
dave
I just returned from a printing workshop in Arizona where Joe was the guest lecturer. He spent a number of hours discussing color spaces (these are not profiles!) which I will reduce to a bottom line. You should use a color space which is the smallest that will hold all the colors contained in the camera file.If you want to use Joes spaces, the ideal space for our digital cameras is DCam3. Both DCam4 and DCam5 are much larger than needed and other spaces e.g. Chrome100 Joseph Holmes is optimized for scanned film images. Joe provides 29 variants with each color space master so that by assigning one of the variants you can go from essentially black and white to quite oversaturated conditions. Remember that you convert to the master space then "assign" one of the chroma variants. Never convert to a variant.
Hope this helps
Woody
Jono and others,
One of the best kept secrets in photography is now
out of the bag; Joe Holmes' colour spaces and numerous
profiles to work with. Here is where to go:
http://www.josephholmes.com/
I would suggest you prepare to spend some time there, and
start with reading his pictures before reading his writing.
If colour is your thing, testing your image by assigning various
Holmes profiles until a satisfactory one seems appropriate can
give a sumptuous quality to post production. And, he's one of
the good guys.
Sincerely...............Chris
Guest guy_mancuso
Hope this helps
Woody
A ha, you learned my secrets. LOL
Good stuff Woody
Guest guy_mancuso
Proof is in the pudding. DMR 19mm
