hi Leica folks,
I'm after my third M-mount lens. I have the newest version of the 50 'cron & the hexanon 50 f2 -- both are wonderful.
I'm looking to buy either a hex 90 f2.8, or a 90 cron pre asph ($500 - $700 range). my question is: does the bokeh on the 90 cron clear up by 2.8? In my experience no lens gives good bokeh wide open -- and trolling flickr reveals -- of course -- some pretty ugly bokeh with this lens wide open. what interests me is how many stops down a lens requires before the bokeh clears up. my 50 1.4 nikkor (f mount) needs to be set two stops down to 2.8 before it becomes usable. on the other hand, my nikkor 85 1.8 is good by 2.8 (1 & a halfish stops), and my M-mount f2 50s clear up after one stop at 2.8 as well.
yeah, so is the 90 cron usable by 2.8? if not, I'll probably just go with the 90 hex, because I'm sure it's fine by f4.
(I hope I'm wrong, but I suspect that generally lenses with huge amounts of glass require more stopping down then lenses that are built more comfortably within physical limits).
similarly, if you've had experience with many of these lenses, is the nikkor f mount 85 1.4 ais usable by f2, or does it need to be stopped down to 2.8?
Cheers,
Raphe
hi Leica folks,
Cheers,
Raphe
Actually, all Leica lenses are designed to be used wide open without any second thoughts. I don't quite follow your post. Bokeh clearing up? I only gets better as you open up the aperture to its maximum...
haha, okay.. well, everyone has different oppinions on this topic
.. but I guess I'm only looking for oppinions from folks who have also found that the quality (not the amount) of bokeh is poor on any lens wide open.
Cheers,
Raphael
...does the bokeh on the 90 cron clear up by 2.8? In my experience no lens gives good bokeh wide open -- and trolling flickr reveals -- of course -- some pretty ugly bokeh with this lens wide open....
Which version of the 90/2 do you refer to? Would you have any link to support this statement? Just curious as i only have an R version of this lens which bokeh is quite smooth i must say.
Get the Apo 90 Summicron Asph. It has a much smoother bokeh wide open than the earlier non-asph version.
I actually really like the bokeh of the traditional spherical optics wide open. This is a case where your mileage may vary.
Well, the "quality" of bokeh is intrinsically a very personal taste... but I think that, in general, if one likes a certain lens' bokeh, so better when it'skept wide open.
In this sense, I prefer my Tele Elmarit 90 to my Summicron 90 pre-asph; also the bokeh of the old Summarex 85 is fascinating (a sort of "crayon-effect" on colors) but is a lens really difficult to focus wide open...reserved for static subjects.
Wow. I actually prefer the 90 'cron pre-asph's bokeh to the asph version in most cases (there's always something that messes up a lens that has even outstanding OOF qualities).
I also prefer the smoother (lower) contrast wide open, since it's easy to add contrast in post but hard to gain the detail the smoother contrast brings.
But that's me
If you can find a good latest model Cron 90 pre-ASPH for $500 - $700 and it's in CLA-d trim, then I'd jump on it.
haha, okay.. well, everyone has different oppinions on this topic .. but I guess I'm only looking for oppinions from folks who have also found that the quality (not the amount) of bokeh is poor on any lens wide open.
Cheers,
Raphael
It seems you are only looking for confirmation of your own opinion. -Which is ummm..slightly eccentric, at least as far as the lenses dicussed in this forum is concerned.
Here is an example of bokeh at f2.8 for three 90mm lenses. Personally I like the Elmarit-M and Summicron-M better than the Tele-Elmarit, but you can't beat the latter for size and weight.
Tele-Elmarit:
Elmarit-M
Summicron-M vII (slight miss on the point of focus)
And the Summicron-M at f2:
- Carl
These are a few examples that I shot last week when I was in Hawaii.
M8/Leitz Canada 90mm Summicron pre-asheric. All shot at f2.
Loading...
    No registered users viewing this page.
  • Similar Content
    • By lebanese blonde
      Hallo miteinander,
      ich habe gestern mal ein paar Vergleichsfotos eines 50mm Summicron v4 (Canada-Version mit Tigertatze) und eines Voigtländer Nokton 50mm 1.5 (1. Version) gemacht.
      Der Test hat keinerlei wissenschaftlichen Anspruch, es hat mich einfach selbst interessiert wie sehr sich die Bilder der beiden Unterscheiden. Bei den Bildern handelt es sich um jpgs direkt aus der M240. Natürlich könnte man auch RAWs vergleichen, aber dazu hatte ich gestern keine Lust 😆
      Die Bilder sind alle ungefähr bei der Naheinstellgrenze aufgenommen, für einen ausführlichen Vergleich müsste man sich natürlich noch weitere Entfernungen, andere Motive und weitere Lichtsituationen anschauen. Es handelt sich wie gesagt um eine Spielerei, vielleicht hilft es ja jemandem der gerade in einer Kaufentscheidung steckt
      Leider hat iMovie nur eine Speicherung in 720p zugelassen, aber auch in der höchsten Auflösung der jpgs ist das Ergebnis in meinen Augen das gleiche.
      Für mich etwas überaschend, ich habe mir einen viel größeren Unterschied im Look erwartet.
      https://youtu.be/l7j3Yck5rS8
      Nachtrag:
      Video eingebettet
    • By oekoek
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
    • By Monochrome_Man
      First of all: hello everybody
      I want to buy Summicron 50mm f2 v3. I have 2 dfferent lens to choose:
      1. lens form about 1969r and it look like this:
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! 2. lens from 1974 and this one is looking as is:
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! In theory both are in good shape, after cla and working good. BUT is any difference beside desgin of lens from 1974 over older one? Price is nearyly the same.
      Second set is more complete, lens hood etc.... but first one is in shop in my city, second one --- only shipping.
      link to wiki: https://www.l-camera-forum.com/leica-wiki.en/index.php/Summicron_(II)_f%3D_5_cm_1:2
    • By jonoslack
      Someone asked about this in the review thread, but I thought it might be of more general interest.
      Images shot on a tripod with focusing via EVF, Camera was M10-R.
      In each group there is 35 summilux at f1.4, at f2 and then APO at f2 followed by a screenshot of 100% magnification of the focused area from Lightroom (f2 shots)
      All shot DNG, with minimal exposure adjustment where necessary.
      FLE at f1.4
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! FLE at f2
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! APO at f2
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Finally a 100% screenshot of the comparison both at f2
      FLE at f1.4
      FLE at f1.4
      FLE at f1.4
    • By samlee.hk
      I got a Light Lens Lab v2LC 35mm f2 Summicron Copy last week
      Overall, the Lenses share similar tone to Leica Summicrion 35/2, with good enough micro contrast, sharp in a relative cheap price level.
      I like using color pic more than BW pic when using v2LC.
      For me, the main difference between Leica Summicron , which can provide a more rich image texture and 3D rendering. But Light lens Labs 35/2 did a good job at this price level.
      Light lens Labs 35mm F2, Leica M10D, TCP Vision3 500T film Preset
      Light lens Labs 35mm F2, Leica M10D, TCP K64 Film Preset
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Light lens Labs 35mm F2, Leica M10D, TCP Vision3 200T film Preset
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Light lens Labs 35mm F2, Leica M10D, LR10.2, Nik Sliver Efex2
      For More PIC and reviews , Please read :
      Light Lens Lab v2LC Summicron 35mm f2
