Sign in to follow this
Bauds
Using M mount 280 Telyt on Lumix G1
I've been reading the fiorums for a while and have found some really useful and helpful stuff. This is my first post so here goes....
I have been using my Telyt 4.8/280 on the Lumix G1 with a Visoflex II which is of course unecessary from the mirror point of view but needed to get the correct distance from the focal plane. Does anyone know of an adapter/spacer the same length as the Visoflex that I can use to make the whole outfit a bit less unwieldy?
I must say that the G1 performance with the Leica lenses is not up to my M8 but it is great as a back-up and also for action shots with the telephoto.
Share this post
Welcome to the club!
At this time, I don't believe anybody produces a dedicated adapter to attach a Visoflex lens to the Micro 4/3 mount directly. You may have to buy two adapters - for example Visoflex to Nikon F mount and Nikon F to Micro 4/3. Or Visoflex to Leica R and Leica R to Micro 4/3..... These adapters exist and I would suggest a search on the Cameraquest site - Adapters: Micro 4/3 or a thorough search on eBay. Lately, all kinds of adapters are coming out of China and are being sold on eBay.
Now - the 280mm Telyt on the G1 will become a 4.8/560mm super telephoto; quite impressive. Holding the combination steady will be a challenge; it would be nice if the G1 had image stabilization built into the body!
Best,
Jan
Share this post
Hi Jan,
Thanks for this information.
I may not have made myself that clear, I actually want to replace the visoflex II unit with an adapter or extension tube. It is not needed for the mirror view and is really bulky. A nice smooth extender would be just perfect.
Neil
Share this post
Hi Neil,
Actually, I understood perfectly what you wanted to do. The only way to do it would be via a tube that allows a Visoflex lens to be mounted directly to an M body, while maintaining infinity focus. If an adapter like that was available (it is not….), you would still need to adapt the combination the Micro 4/3 mount.
I assume that you have the Leica M to Micro 4/3 mount, as that is how the Visoflex gets attached to your G1. So - the only way (to my knowledge…..) to attach the Telyt to the G1, would be via extra adapters - this is a complicated and relatively costly way but, at this time the only way.
Best,
Jan
Share this post
Loading...
  • Similar Content
    • By LocalHero1953
      Leica TL2 black body, boxed and complete (straps, cable, instructions, charger, alternate power socket pins).
      Additional two batteries (3 total), matching Visoflex EVF Type 020, steel lug pins (2 nr), black dummy pins (2 nr), lug pin removal tool.
      Excellent condition, no significant marks, fully working with no problems. The outer box is a bit tatty at the closure point but intact.
      I bought the TL2 a year ago, used, from the Leica Shop, Vienna, as a back up for my CL for travel. I would keep it but it has been replaced by a full-frame Sigma fp.
      The TL2 sells for just under £1000 on ebay, and the Visoflex for another couple of hundred pounds. Including the Visoflex and batteries, this is a bargain!
      Postage or courier charges will be added at cost, to be agreed before final sale.
    • By Charadis
      I recently found a super deal on a Visoflex 020 being sold by Adorama through auction listed as having major defects; the details described as "** Item Notes: Viewfinder does not switch back to LCD screen properly; Likely proximity sensor issue; May have other issues; Cosmetic condition is E **
      However, the price was too good to pass up, less than half price of a brand new one. So I took a chance and bought it. When I received and tried it out, to my surprise, it worked, but there were green lines across the display. The lines went away when I angled the viewfinder to the max 90 degrees angle, but only temporarily. Issue returned when I adjusted the angle of the viewfinder again.
      I spent the latter half of a Friday evening/night before I pinned the problem down to the LCD connection to the main board. I started disassembling the base module where the unit connects to the camera at the hot shoe. There are four screws at the bottom, then the top of that module can be lifted up and out. There is a swinging door with the tiniest spring that attaches to that top piece, very easy to lose. The door can fall off easily. The hot shoe connection can then be disconnected from the metal hinge assembly by removing two silver screws and pushing back the two plastic tabs securing the connector to the hinge plate.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
      To disassemble the main eyepiece module, the rubber eye "hood" or protector had to be removed; it is held in by double-sided adhesive at the top and bottom inside. Behind that, there are two screws left and right flanking the eyepiece that hold the upper and lower housing together. After I removed those, I spent a lot of time working the housing, trying to figure out if there were any other screws, or if adhesive or tabs were holding them together. Turns out, I took a chance and found out there is a tab on each of the three sides. The bottom comes off, and the main assembly is attached to the top housing.
      The ribbon flex cable connecting the base module to the eyepiece main module had no signs of damage; connection was fine, and removing/reattaching it did not resolve the green-lines issue. There were no breaks on the flex. However, pushing the flex beneath made the green lines disappear temporarily. So I removed the mainboard from the top housing assembly, and found a misaligned connection between eyepiece LCD and the mainboard: see, the connection is crooked
      It may have dislodged from the connector after a drop, or perhaps maybe it was never properly installed at the factory. Or maybe the continued adjusting/angling of the viewfinder furthered the loose connection? In any case, removing and reinstalling the connection made the green lines disappear and have not reappeared ever since I reassembled everything together.
      I tested the eyepiece multiple times on my TL before reassembling everything back together.
      Gotta say, I'm very happy with the viewfinder. Though it seems to pale in comparison to the viewfinder in my recently acquired CL, it is still a very welcome addition. And very fun to use. I'm not a serious photographer, but I'm slowly working my way into a new hobby..
      Some background; I have repaired other people's smartphones in the not too distant past, and I collect and repair vintage Macintosh computers. After my experience with the TL, Leica cameras are working their way into becoming a new part of my collection.
    • By J-T
      Hi
      I've been procrastinating for a very long time over getting something to work with my M9P for macro work - specifically taking shots of antique/vintage fountain pens I've restored for sale or show.
      Technically I should be looking at a whole different camera (or digital Visoflex if I had a later M camera) but it would be great to get something working with the outfit I currently have.
      To start with I have a Visoflex III and I have my M9P and a few lenses that suffice to say don't work well for close up.
      I'd like to keep this simple and not break the back and I've figure out I'm probably looking at a v2 Elmar-V 65mm f3.5 which is a relatively 'meh' lens specifically built for the Visoflex and won't work directly on the M9 but apparently but does the job.  The Macro Elmar-M 90mm f4 has far too many zeros in the price even for a used one and it is indeed a nice lens.
      Here is where I am:
      1. Elmar-V 65/3.5 + 16464 universal focusing mount (OTZFO) + 16471 (OTPRO) ring extension
      2. Tele-Elmar-M 135/4  + 16464 universal focusing mount (OTZFO) + 16471 (OTPRO) ring extension
      Option 1 gives me infinity to 330mm (13") or 330mm - 270mm focusing distance with EF= 2x or 3.4x (apparently)
      Option 2 gives me infinity to 980mm (38.5") or 980mm - 680mm focusing distance with EF = 1.4x or 2x (apparently)
      I'm going to say the despite the Tele-Elmar being a significantly more useful lens outside macro work and with a significantly better optical formula its probably going to be a pain to use for my application use case.
      I could look at getting the bellows adapter for the 135/4 but suspect this is just going to get a little unwieldy and out of hand.
      Thoughts/experiences?
    • By DirkR440
      How about an open thread about pictures of and taken with Visoflex lenses.
      Let me start with the 280mm mounted on the Visoflex III:
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Leica MP with Visoflex III and 280mm by Dirk Raffel, auf Flickr
      Sample picture:
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Zürich by Dirk Raffel, auf Flickr
      or with the Monochrom:
    • By thowi
      Hallo zusammen,
      da hier und da schon einmal nach dem Puts-Kolumnen für die R-Objekive gefragt wird, möchte ich diese hier zusammenhängend veröffentlichen. Die Kolumnen wurden damals bei Leica frei veröffentlicht, sind jedoch heute nicht mehr verfügbar.
      Es handelt sich hier um insgesamt 17 .pdf Dateien die aufgrund ihrer Größe nicht in einen Beitrag passen.
      Gruß
      Thomas
    No registered users viewing this page.
Important Information
