Paradox
wilfredo
Why is it that Leica shooters seem to be obsessed with sharpness when most of the stuff published in Leica Fotografie International is hardly ever sharp or even close to outstanding in terms of image quality, and the great historical pictures taken by Leica photographers don't fall under the criteria of outstanding image quality and sharpness either?
This seems to be a paradox I don't quite comprehend, yet many will pay thousands for a Leica optic (I'm also guilty).
Cheers,
Wilfredo+
Benitez-Rivera Photography
Wilfredo,
good question. I guess it could be that we sometimes confuse technical excellence in cameras and lenses with aesthetic excellence in images and photographs. Of course, most of us Leica photographers appreciate both :rolleyes:
Wilfredo,
It's not about sharpness if you mean resolution. Never was. Leica has always known that contrast and what you can see counts. This is about compromises in color correction and resistance to veiling glare and flare. It's the richness and what your eye can perceive that counts. The rendition makes the optics worth the $$$ and they create the WOW factor.
JR:
I guess I appreciate both myself.
William,
I understand the wow factor you write about but I often find these missing in Leica publications (not always but often) so I wonder about this?
In my experience not all Leica lenses are the same, I started out with a 28mm ASPH Summicron in the wide angle department but found that skin tones looked too pastey and pale with that lens. I sold it and replaced it with the 35mm ASPH Summicron and I'm really happy with the skin tones I get from this lens. In the end, for me, artistic value remains above technical merit but it's nice to think one's equipment will deliver the best possible image.
Cheers,
Wilfredo+
One never complains about having too sharp a lens, too much money or too long a ...
A sharp lens can be used to take soft photos-- simply put a soft filter or do a gaussian blur after a scan.
A soft lens cannot be used to take a sharp photo. You can't reintroduce sharpness to a photo.
Basically then, the answer is-- because people want the best, even if they don't really use it.
