Trutta Posted 2 hours ago Share #1 Posted 2 hours ago Advertisement (gone after registration) I’m new to the M5 and was curious if this version of the Leica 21mm f/2.8 Elmarit-M [11134] serial number 3685072 is compatible with the M5? Any help would be great! Link to post Share on other sites More sharing options...
Advertisement Posted 2 hours ago Posted 2 hours ago Hi Trutta, Take a look here Leica 21mm f/2.8 Elmarit-M [11134]. I'm sure you'll find what you were looking for!
Alexander108 Posted 1 hour ago Share #2 Posted 1 hour ago Any M lens is compatible. What makes you believe that this might not be the case? Link to post Share on other sites More sharing options...
lct Posted 1 hour ago Share #3 Posted 1 hour ago The Elmarit 21/2.8 protrudes less into the body than the Super-Angulon 21/3.4 so it should fit at least as well as the later which is compatible with the M5 but i have no experience with the M5 sorry. Link to post Share on other sites More sharing options...
Trutta Posted 1 hour ago Author Share #4 Posted 1 hour ago 28 minutes ago, Alexander108 said: Any M lens is compatible. What makes you believe that this might not be the case? The back end of the lens can interfere with the light meter arm, that was the reason I was asking. 1 Link to post Share on other sites More sharing options...
BernardC Posted 1 hour ago Share #5 Posted 1 hour ago The Elmarit M was released after the M5. It is compatible, unlike the f:4.0 21 Super-Angulon. The 3.4 Super-Angulon is compatible if built in 1971 or later (some earlier lenses may have been modified to fit). Link to post Share on other sites More sharing options...
Trutta Posted 1 hour ago Author Share #6 Posted 1 hour ago Thank you! Link to post Share on other sites More sharing options...
