A picture is a thousand words...
SL75mm APO
SL90mm APO
Edited by Planetwide
SL75mm APO
SL90mm APO
Indeed. Thanks for this. The busy oof area with the 75mm cured my desire for this lens. If, and it is still an if, I want a more tighter portrait lens, I will most probably go for the 85mm sigma…
Personally, the 75mm is one of my favourites. I like the slightly wider field of view. It's bokeh is, like all lenses, background dependant.
the 90mm
  • 4 weeks later...
On 11/30/2024 at 9:49 AM, Olaf_ZG said:
So, having a 21mm, the Q 43, what would be a better fit? The 75 or 90? Don’t want both. …
I’m using the 21 & 35 APO along with the 50 Summilux SL. I also shoot the 75 Noctilux which is IMO too close to the 50 so either lens can suffice in a pinch.
For something longer I’ve been using my old Contax Zeiss 100mm F2 Planar while I decide the final SL prime lens for my kit.
My current mind set is leading me more towards the APO Summicron SL 90 as the logical choice. YMMV
My current kit is the 21, 35, 75 APO SL and the 50 Lux SL (just sold the 50 APO SL).  I don"t miss the 90 at all - but in your case the 90 probably makes more sense already having two lenses that can fill in the gap.  Truth be told I usually don't carry the 50 and for a travel kit It's just the SL3/21 APO and Q3 43.
