On 8/29/2024 at 6:06 AM, Smudgerer said:
A bit of an aside but I couldn't resist it.....I loved, still love the Cooke 5:1 20-100 you own, what a great lens for flesh tones, the same goes for the Cooke 3:1 20-60 T3.1 which I slightly preferred. When I still had my S16 Aaton Xtera I also had the 10-30 t1.6 Cooke, heavy but damn useful for HH night shoots with 800' mags stuffed with 7218.......Those were the days!!! I worked a lot of TV dramatic episodic  series shoots with that combination.
But back on subject, sort of, if the OP wants a bit more speed and would like to stick with 35mm FL the Voigtlander Nokton Classic 35mm 1.4 is a great option and easier on the wallet too. I tried a friend's MATE last year and didn't like it's physical length on the M body, way too much VF blockage, it's results were "ok" but nothing that would make the lens an attractive proposition for me.
I already have the Summicron 35 f2 Asph... My current lens is fantastic and serves me well. My interest in the MATE relates to my desire to not change lenses in the field. The MATE allows you to have 3 focal lengths in one package. I was / am trying to avoid buying two cameras. Months later, I am now thinking about getting a second M10 and adding a 75mm f2.4... thus I'd have one body with a 35mm lens and a second with a 75mm lens. I am just not all that excited about spending $5000 or so make this happen.
bruce
Though V1 has a very shallow dedicated built-in lens hood , Leica offered a square external hood. It helps to reduce flare, but did not fixed the weird ghost flare. V2 is meant to fixed the problem but the external dedicated round hood is still much appreciated.
In my experience, the V2 flare can be consciously avoided, but V1 flare is simply unpredictable. That is why I gave up V1.
By the way, I had V2 while I had M9. I found the 6-bit code and the on-body FL switch is very useful to work with LR lens correction.  Since I had no ZM lens correction, it beats ZM 28mm in the “Xmas light” aberration problem. .
bruce
Bruce, with careful choice of viewpoint, and skillful use of your left hand, you can markedly reduce the risk of vignetting when using any lens.
bruce
Hello again, as I said in the previous post the main thing I didn't like about the MATE was it's size and the VF obstruction, otherwise it seemed pretty decent.........
32 minutes ago, Smudgerer said:
VF obstruction
Real problem at 28mm.
In real use, I forget the problem after a while like using large hood on my other 28mm lenses (Summicron-M 28 for example).
In doubt, I can use liveview but for these days very rarely/never.
Yes, agree, my e49 MATE does block the 28mm viewfinder a bit in the lower right,  but I just had to mount it now to take a fresh look, as I really never noticed before or at least found it very bothersome or inhibiting. My 28 lux (yes, it’s a large lens) blocks more of the viewfinder than my e49 MATE for comparison.
Edited by RMF
