dawskip Posted January 2, 2024 Share #1  Posted January 2, 2024 (edited) Advertisement (gone after registration) Hey guys!  So I'm going to attempt to use an orange filter for the first time and have some questions. Using a M2 w/ a voigtlander 1.5 35mm. I use a Keks light meter / sunny 16 occasionally. Was planning on shooting Kiki pan 320 or HP5, probably both.  How should I meter my images? Should I do +2 stops? Should I just shoot it at box speed / normal metering?  Also, to add, I'm going to mostly be shooting outdoor, direct sunlight on the beach. Blue skies / lots of light.  Also have a yellow filter, not sure if im going to use it yet, but same Q's for that one.  Thanks for the help! Edited January 2, 2024 by dawskip Added details Link to post Share on other sites More sharing options...
Advertisement Posted January 2, 2024 Posted January 2, 2024 Hi dawskip, Take a look here Using a Leitz Wetzlar Orange (Or) Filter on a m2.. I'm sure you'll find what you were looking for!
jaapv Posted January 2, 2024 Share #2 Â Posted January 2, 2024 Yellow 0.5 - 1.5 compensation (light-mid-dark), Orange 1.5-2 compensation. I should be marked on the filter ring. Link to post Share on other sites More sharing options...
a.noctilux Posted January 2, 2024 Share #3  Posted January 2, 2024 Compensation is something to learn to use. Rule of thumb is metering through the filter then bracket from that (what I do when bracketting is possible). "Right exposure" depend on many variables like the main/oppposite colors, the b&w film in use color respondings, etc. Sadly, there is no magic formula for this. 1 Link to post Share on other sites More sharing options...
rustyrus Posted January 2, 2024 Share #4  Posted January 2, 2024 I would meter on the blue sky if you can, then add 1.5 stop- Better yet just set to over expose by 1.5 on the light meter and go with it. That is a good starting place out doors with an Orange Filter- Good Luck  Link to post Share on other sites More sharing options...
dbeids Posted January 3, 2024 Share #5 Â Posted January 3, 2024 The filter factor should be marked on the rim of the filter. Use that as a start. Link to post Share on other sites More sharing options...
Pyrogallol Posted January 3, 2024 Share #6 Â Posted January 3, 2024 For orange give it about 1.5 or 2 stops extra. Link to post Share on other sites More sharing options...
