erniethemilk Posted November 17, 2023 Share #1 Posted November 17, 2023 Advertisement (gone after registration) Anyone have thoughts on these two. Currently have the ‘cron but not overly happy with performance on my M10-P. The veiling is quite obvious at times & thinking I might switch out to a Summilux. Should I see much difference in the performance of one against the other at any given aperture? Link to post Share on other sites More sharing options...
Advertisement Posted November 17, 2023 Posted November 17, 2023 Hi erniethemilk, Take a look here 50mm Summicron v5 v Summilux 50 1.4 ASPH. I'm sure you'll find what you were looking for!
RexGig0 Posted November 17, 2023 Share #2 Posted November 17, 2023 (edited) Veiling flare is present with the Summilux-M 50mm ASPH, too. I have not done a side-by-side torture test, in flare-inducing conditions, with my Summilux and Summicron v.5 lenses, but can assert that the Summilux does flare. I have tested my newly-acquired Cosina Voigtlander 50mm APO Lanthar, and Summilux-M 50mm ASPH, side-by-side, in flare-producing conditions. The APO Lanthar won that one, as I anticipated. The new APO Lanthar does not threaten to kick any of my Leica lenses from the nest. Flare can be used creatively. The APO Lanthar is simply a tool, to use when flare must not be allowed to happen. My test images are not in ready-to-share condition, but here is a reasonably-brief you-tube presentation, that shows the CV 50mm APO Lanthar competing against the Summilux-M 50mm ASPH and the APO Summicron 50mm ASPH, with flare susceptibility being one of the tests: Voigtlander 50mm APO vs. Leica 50mm APO and Summilux ASPH | A detailed comparison review" width="200"> Edited November 17, 2023 by RexGig0 1 Link to post Share on other sites More sharing options...
