Trutta Posted October 27, 2023 Share #1  Posted October 27, 2023 Advertisement (gone after registration) Starting to venture out of my comfort zone of wide angle lenses. I hoping to get some questions answered. I shoot a M1, so no rangefinder and only 35 and 50mm frame lines. The prices for this lens is really attractive so it might be worth the gamble. I just shoot using the lens for everything I do. I read that with the goggles it gives the 90mm frame lines equivalent to 135. What effect would it have on 50mm lines on the M1, would it be a step to 90mm? Or would it be non relevant to the 50 and just give a focus for the 135mm through the viewfinder? once again thanks guys!! Link to post Share on other sites More sharing options...
Advertisement Posted October 27, 2023 Posted October 27, 2023 Hi Trutta, Take a look here Curious about the LEITZ (LEICA) 135mm f/2.8 with goggles. I'm sure you'll find what you were looking for!
a.noctilux Posted October 27, 2023 Share #2  Posted October 27, 2023 I don't have M1 but I can confirm that the auto indexing of this 2.8/135 is 90 framelines and combining with the x1.5 VF device can comfortably help framing more accurately. I don't know if frame "auto indexing" works on M1, if so no framelines (90 not present) If your M1 don't have 90 framelines, you can guess the framing as you can guess the focussing.  Link to post Share on other sites More sharing options...
EJS73 Posted October 28, 2023 Share #3 Â Posted October 28, 2023 The goggles magnify the view about 50% and add significant vignetting; I don't have experience with the M1, but an educated guess is that the magnified 50% frame (approx 75mm effective) will fall outside the viewable area. Link to post Share on other sites More sharing options...
Trutta Posted October 28, 2023 Author Share #4  Posted October 28, 2023 Thanks guys!! Link to post Share on other sites More sharing options...
dpitt Posted October 28, 2023 Share #5  Posted October 28, 2023 20 hours ago, Trutta said: Starting to venture out of my comfort zone of wide angle lenses. I hoping to get some questions answered. I shoot a M1, so no rangefinder and only 35 and 50mm frame lines. The prices for this lens is really attractive so it might be worth the gamble. I just shoot using the lens for everything I do. I read that with the goggles it gives the 90mm frame lines equivalent to 135. What effect would it have on 50mm lines on the M1, would it be a step to 90mm? Or would it be non relevant to the 50 and just give a focus for the 135mm through the viewfinder? once again thanks guys!! Because you do not have a rangefinder, I think the main issue will be to focus your 135mm correctly. Unless you use a tape measure (or external RF) and use the meter scale on the lens as a guide, I do not see how you could get acceptable results. DOF at f2.8 will be very small. Framing is fairly easy. Just use the focusing patch and imagine a frame that is three times the with and height of the patch around it. Link to post Share on other sites More sharing options...
UliWer Posted October 28, 2023 Share #6  Posted October 28, 2023 vor 42 Minuten schrieb dpitt: focusing patch An M1 - having no rangefinder - doesn't have a focusing patch. It was not meant to be used with longer focal lengthes. 1 Link to post Share on other sites More sharing options...
dpitt Posted October 28, 2023 Share #7  Posted October 28, 2023 Advertisement (gone after registration) 🤔 @UliWer Yes, that sounds logical. I never had the chance to handle an M1, so did not think of that. Then it seems like an external 135mm OVF is the best way to frame it. And of course the VIOOH will do the job as well. Link to post Share on other sites More sharing options...
Jean-Michel Posted October 28, 2023 Share #8  Posted October 28, 2023 I have the 135 Elmarit (with goggles). It is a fine lens if rather clunky – these days I occasionally use it withy M-P(240) and the EVF, or with the SL2. I do not imagine trying to use this lens with the M1, maybe it would work for images made at infinity, but anything closer and the likelihood of getting any image in focus is close to nil. Link to post Share on other sites More sharing options...
Trutta Posted October 29, 2023 Author Share #9  Posted October 29, 2023 (edited) Thanks guys, I think it would work for landscapes at hyperfocal focusing, unfortunately I’m not into portraits so it would be used for that, I can see where the trouble would start without a coupled rangefinder for middle range and closer points of focus. But my original query was the effect on the frames with the goggles magnification. Edited October 29, 2023 by Trutta Link to post Share on other sites More sharing options...
a.noctilux Posted October 29, 2023 Share #10 Â Posted October 29, 2023 In this case it would work without focussing at all. Just set the lens at infinity stop then enjoy. Framing loose can be done with the "whole" M1 viewfinder ( so with the x1.5 use, of course ). I just had a look how close is the 50/75 framelines, on my M-A with field selector. In this case, no frameline visible, I think it's the same as your M1. Then you can see after some "calibration" ( real use with some tests ) how the framing is with your M1. Have fun. Link to post Share on other sites More sharing options...
