lifeandmylens Posted September 30, 2023 Share #1 Â Posted September 30, 2023 Advertisement (gone after registration) I came across a topic here once discussing this, but can't seem to find it now. Â Also remember most of the suggestions were no longer available. Â 41.5mm step up rings that I've tried don't fit. Â So, is anyone using a ND filter with the steel rim (original)? Â If so, what are you using? Â I have the matching Leica UVa filter for it (which has no front threads), but I don't have a ND filter. Link to post Share on other sites More sharing options...
Advertisement Posted September 30, 2023 Posted September 30, 2023 Hi lifeandmylens, Take a look here ND Filter for Steel Rim Original. I'm sure you'll find what you were looking for!
grahamc Posted October 1, 2023 Share #2 Â Posted October 1, 2023 Tricky one. I use the original E41 filter when not needing ND, then remove and use a Eb*y E41 to 40.5 step down ring to house a 40.5mm ND (widely available)Â 1 Link to post Share on other sites More sharing options...
lifeandmylens Posted October 1, 2023 Author Share #3 Â Posted October 1, 2023 5 hours ago, grahamc said: Tricky one. I use the original E41 filter when not needing ND, then remove and use a Eb*y E41 to 40.5 step down ring to house a 40.5mm ND (widely available)Â Thanks Graham, will try that! Link to post Share on other sites More sharing options...
