Greenhilltony Posted September 21, 2023 Share #1 Â Posted September 21, 2023 (edited) Advertisement (gone after registration) Every user of Summicron-C 40 / M-Rokkor 40 / Voigtlander Nokton Classic 40 should have known the 35mm framelines can be activated by not fully rotate the lens to click when mounting, because there is a little bit of extrusion on the part of the flange for frameline activation. The main finding and conclusion from me is: this method works if the lens focus cam is the parallel style, which means the CLE version M-Rokkor (with serial numbers on barrel) and Voigtlander 40/1.4 benefit from this trick. When the focus cam is parallel, it couples with the lever in body by purely back and forth motions. So rotating the lens a bit backward does not affect the focus cam positions. On the other hand, the sloped focus cam used on Summicron-C 40 and the early M-Rokkor 40 made for CL brings trouble when you do the incomplete mounting trick. The coupling lever does not stay in place once you rotate the lens: as the focus cam is sloped, the lever will contact with the lower part of the cam, indicating a closer position to the rangefinder. It means the lens now is unable to be focused at infinity position, most obviously, and always focus a bit closer through out the 0.8m-infinity range. Edited September 21, 2023 by Greenhilltony Link to post Share on other sites More sharing options...
Advertisement Posted September 21, 2023 Posted September 21, 2023 Hi Greenhilltony, Take a look here Activating 35mm framelines for 40mm lenses without filing the flange: a bit additional info about focus accuracy. I'm sure you'll find what you were looking for!
dpitt Posted September 21, 2023 Share #2 Â Posted September 21, 2023 Ages ago, when I used my unmodified 40mm Summicron C. I posted a hack, where I locked the frame line lever into place by inserting a small piece of plastic under the lever. This way I could use this lens with 35 mm frames. I now have a modified version that brings up 35mm framelines in stead of the standard 50mm lines. These framelines are quite accurate for the 40mm when you stay inside the lines. Link to post Share on other sites More sharing options...
dpitt Posted September 21, 2023 Share #3 Â Posted September 21, 2023 I found it: Â Link to post Share on other sites More sharing options...
