Lew Posted August 12, 2023 Share #1 Posted August 12, 2023 Advertisement (gone after registration) This lens does not appear to be threaded for filters, thus a metal screw on will not work & can't be found anyway. Where can I get a replacement push-on? OEM not important. Link to post Share on other sites More sharing options...
Advertisement Posted August 12, 2023 Posted August 12, 2023 Hi Lew, Take a look here Lens Cap for Summilux 1.4/35. I'm sure you'll find what you were looking for!
lct Posted August 12, 2023 Share #2 Posted August 12, 2023 (edited) • Edited August 12, 2023 by lct Link to post Share on other sites More sharing options...
Lew Posted August 12, 2023 Author Share #3 Posted August 12, 2023 That is indeed what I mean & thanks. I'm am looking for a cap, not the hood. Link to post Share on other sites More sharing options...
lct Posted August 12, 2023 Share #4 Posted August 12, 2023 Assuming your Summilux 35/1.4 non asph is a version 2 (11870), the regular lens cap is the Leica 14143 black plastic cap for it but any push-on A42 lens cap should fit like Leica 14003 (metal black paint), 14031 (metal silver), 14268 (plastic black), 14285 (metal black anodized), or 14321 (metal silver). Less expensive A42 copies can be found on Amazon or eBay. Link to post Share on other sites More sharing options...
weatherproof Posted December 22, 2023 Share #5 Posted December 22, 2023 Is 42mm the measurement of the outer diameter of the Summilux v2 pre-asph (11870) for caps that slip over the the front? Could one use a pinch cap instead? What would the inner diameter be? Thank you. (As an aside, I roll my eyes at sellers that somehow can't include even a $5 cap for such an expensive lens.) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/380829-lens-cap-for-summilux-1435/?do=findComment&comment=4956330'>More sharing options...
lct Posted December 22, 2023 Share #6 Posted December 22, 2023 28 minutes ago, weatherproof said: Is 42mm the measurement of the outer diameter of the Summilux v2 pre-asph (11870) for caps that slip over the the front? Yes if the serial number of your lens is 2166701 or above. Link to post Share on other sites More sharing options...
lct Posted December 22, 2023 Share #7 Posted December 22, 2023 Advertisement (gone after registration) 36 minutes ago, weatherproof said: Could one use a pinch cap instead? What would the inner diameter be? [...] Leica did not offer pinch-on caps for this lens AFAIK. Generic 41mm ones could fit i guess but i did not try. As far as A42 push-on lens caps are concerned, the regular one was the Leica 14143 black plastic cap if memory serves but the following ones will fit too: Leica 14003 (metal black paint), 14031 (metal silver), 14268 (plastic black), 14285 (metal black anodized), or 14321 (metal silver). Link to post Share on other sites More sharing options...
weatherproof Posted December 22, 2023 Share #8 Posted December 22, 2023 (edited) 19 minutes ago, lct said: Leica did not offer pinch-on caps for this lens AFAIK. Generic 41mm ones could fit i guess but i did not try. Thanks lct. I should have googled harder, but it looks like one wants a 39mm pinch cap. Sources: - https://www.photo.net/forums/topic/210267-lens-cap-size-for-35mm-summilux-pre-asph/ - https://www.fredmiranda.com/forum/topic/1788123/3 (German w/ serial 3433xxx) And for anyone who wants a cap for the 12504 hood, this thread was helpful: Edited December 22, 2023 by weatherproof add 12504 info Link to post Share on other sites More sharing options...
lct Posted December 22, 2023 Share #9 Posted December 22, 2023 4 minutes ago, weatherproof said: [...] looks like one wants a 39mm pinch cap [...] I used to try Fuji and Voigtlander 39mm pinch-on caps on my German made 35/1.4 v2 from 1989 (35015**) but they tended to fall off too easily. Link to post Share on other sites More sharing options...
RexGig0 Posted December 22, 2023 Share #10 Posted December 22, 2023 (edited) Kaiser provides well-made, push-on lens caps, in an assortment of inner diameters. It is the responsibility of the user to measure the lens, filter, or whatever object is to be capped. This link is for one of the sizes, 49mm, that I randomly selected to copy and paste. There is a drop-down menu for selecting other sizes. https://www.bhphotovideo.com/c/product/125281-REG/Kaiser_206949_49mm_Push_On_Lens_Cap.html My only “relationship” with B&H is that of a paying customer. Edited December 22, 2023 by RexGig0 Link to post Share on other sites More sharing options...
weatherproof Posted February 4, 2024 Share #11 Posted February 4, 2024 On 12/22/2023 at 12:42 PM, lct said: I used to try Fuji and Voigtlander 39mm pinch-on caps on my German made 35/1.4 v2 from 1989 (35015**) but they tended to fall off too easily. Following up for posterity, I measured the ID of my '92 v2 Summilux and it was ~39.8mm. I had a generic 40.5mm pinch cap and that worked, but only because when fully compressed the springy bits go down to ~39.4mm. Don't know how common this is or if I lucked out with sample variation. Link to post Share on other sites More sharing options...
lct Posted February 5, 2024 Share #12 Posted February 5, 2024 23 hours ago, weatherproof said: [...] I measured the ID of my '92 v2 Summilux and it was ~39.8mm. I had a generic 40.5mm pinch cap and that worked, but only because when fully compressed the springy bits go down to ~39.4mm. [...] I did not measure anything but the 40.5mm pinch-on cap of my M-Rokkor 40/2 fits well my Summilux v2 too. Link to post Share on other sites More sharing options...
evikne Posted February 5, 2024 Share #13 Posted February 5, 2024 (edited) My lens was equipped with this nice cap with embossed Leica logo and red felt inside. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! It's pretty similar to this one: https://www.ebay.com/itm/385576447397?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=vx4sfj7rtoc&sssrc=2047675&ssuid=&var=653399422818&widget_ver=artemis&media=COPY Edited February 5, 2024 by evikne Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! It's pretty similar to this one: https://www.ebay.com/itm/385576447397?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=vx4sfj7rtoc&sssrc=2047675&ssuid=&var=653399422818&widget_ver=artemis&media=COPY ' data-webShareUrl='https://www.l-camera-forum.com/topic/380829-lens-cap-for-summilux-1435/?do=findComment&comment=5023486'>More sharing options...
