i have a 67mm female to female adapter on the way to me to try using filters on the 21lux
i already have a 58mm f2f adapter plus a step up ring to use my 82mm filters with the 18mm super elmar
i should have the adapter in the next few days
Edited by overexposed
Thanks so much! I would love to hear your thoughts once you receive it :) Especially regarding vignette as that's what I'm most interested about
So i received the 67mm f2f adapter, and it doesnt fit properly on the 21lux, because as you can see in the pictures, #1 18mm super-elmar, #2 21lux, there is a bit offset elevation.
the 67mm diameter is correct though. it seems the front lens would be as exposed as the 18mm lens, was the offset made to protect the front lens a bit more?
i can screw the adapter on the lens but it feels like it wont be healthy for the lens thread over time.
also with the 21mm, there is a light leak at the mount, just like with the 18mm. #3 lower edges, 8min exposure
Thanks so much! Very good to know, looks like I'll have to order the 82mm adapter and get new filters
