Just had a quick trawl for 21mm SEM & M11 images on my MacBook and this is one example - imported into LR Classic, SEM profile applied, 'auto' clicked and exported as 2480px jpg.  Unlike when I had a ZM 21mm Biogon f2.8 on my M9, here there do not appear to be any corner colour-casts (or the dreaded 'Italian flag'!).
I have no experience with the Biogon 21/2.8 but i suspect it would not cause any color cast on the M11, thanks to the latter's BSI sensor. Same for both my Biogon 21/4.5 and Super-Angulon 21/3.4.
Edited by lct
5 hours ago, Kwesi said:
hopefully its the lens.
My gut feeling is that the M11 for whatever reason, is not applying the correction although its reading the code.
one way to test is by fooling the camera into thinking that the lens is uncoded and then applying the 21/2.8 correction and seeing if that gives a better result.
take a piece of white paper and lay it over the code reader before you mount the lens. my guess is that'll be enough to trick the M11 into thinking its an uncoded lens
Aere is the lens auto coded as the Super Elmar 21
Here is the lens manually coded (covered the coding sensor with a piece of post it)
both shot at f11, no adjustments at all
So it appears this is a coding issue? I am running the latest firmware on the M11, 1.6.1
im assuming the 21 SEM 6 bit code area is clean?
Also perhaps try a white wall with about a one stop over exposure from the meter reading. Your images seem underexposed. not the cause of the problem but it does make it hard to see the magenta cast against the dark clouds.
It may be worth it to restore camera to factory settings and try again.
Yes should be all brand new clean, as its all less than a week old..... and the images are coded correctly, so I am presuming the coding is either readable or not.
Been busy with work but will test further - I did do a factory reset after installing 1.61, though not after trying this lens for the first time..
I also emailed Leica customer care with some sample images to get their feedback. Although yes, those images above were underexposed, the overall look of the manually encoded is still less magenta overall I would say
Edited by thrang
6-bit coding does not bring significant color modification in my experience, at least as regards color shifts or lack thereof out of BSI sensors. Just to show what happens when removing the Leica color profile from DNG files below (M11 + coded SEM 21/3.4 asph, f/8).
With Leica color profile:
W/o Leica color profile (DNG matrix):
I don’t know enough about lens design to determine wether the lens is defective. Perhaps the thing to do is to return it. This will at least rule out sample variation if the problem persists. Curious to hear what Leica has to say.
Yes replacement was ordered and arrives today - will post comparisons if warranted as well as Leica response.
is customer.care@leica-camera.com the right email for such support?
The sky is a complex object, especially with wide angle lenses. I think it has to do with polarisation and other effects, but take that with a grain of salt. If you want to check your lens regarding color casts, use something neutral like a uniform while or grey surface.
I suspect both your camera and lens are OK so i would not hold my breath but i may be wrong and asking Leica is the way to go anyway.
