Adam_James Posted June 9, 2023 Share #1 Posted June 9, 2023 Advertisement (gone after registration) Hello all, Toying around with the idea of buying a Contax 645 Carl Zeiss 35mm F3.5 Distagon T wide angle lens to use on my Leica SL2-S for tripod landscape work. Anyone use Contax 645 lenses in Leica L mount? What was your experience? Thanks for your responses, Adam Quote Link to post Share on other sites More sharing options...
Advertisement Posted June 9, 2023 Posted June 9, 2023 Hi Adam_James, Take a look here Using Contax 645 lenses on SL2/SL2-S any experience?. I'm sure you'll find what you were looking for!
LeicaR10 Posted June 9, 2023 Share #2 Posted June 9, 2023 Adam_James, You might want to take a look at this Leica Forum link on this subject. r/ Mark Try: Quote Link to post Share on other sites More sharing options...
Stuart Richardson Posted June 9, 2023 Share #3 Posted June 9, 2023 Personally, I don't think you really have anything to gain by doing this. The lenses are big and heavy, and they are not really as good technically as more modern options. The native 35mm APO Summicron SL is one of the best lenses ever made, so if you can afford even a used copy of that, it is certainly the best way to go for landscapes. If you want a extremely sharp landscape lens but cannot afford or do not want the native lens, the 35mm Voigtlander APO Lanthar M will be compact, light and a better performer than the Contax. If you want character lenses, there are tons of 35mm lenses for the 35mm format that likely have the combination of atmosphere and performance that you are looking for in a smaller package...probably even Contax's own 35mm lenses. Quote Link to post Share on other sites More sharing options...
ynp Posted June 9, 2023 Share #4 Posted June 9, 2023 Is there any Contax645 to L mount adapter in existence? Quote Link to post Share on other sites More sharing options...
Adam_James Posted June 9, 2023 Author Share #5 Posted June 9, 2023 Hello ynp, Yes it is made by Kipon. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/378084-using-contax-645-lenses-on-sl2sl2-s-any-experience/?do=findComment&comment=4790567'>More sharing options...
ynp Posted June 9, 2023 Share #6 Posted June 9, 2023 1 hour ago, Adam_James said: Hello ynp, Yes it is made by Kipon. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Thank you for the info. Does it allow for the aperture control? Quote Link to post Share on other sites More sharing options...
Adam_James Posted June 9, 2023 Author Share #7 Posted June 9, 2023 Advertisement (gone after registration) Ynp, I’m not sure about aperture control. I just found the adapter online last night when I should’ve been sleeping… 1 Quote Link to post Share on other sites More sharing options...
siddhaarta Posted June 9, 2023 Share #8 Posted June 9, 2023 (edited) It is a dump adapter, so you only can use the lens wide open. And it has a focal reducer with factor 0,7 with lens elements inside. Edited June 9, 2023 by siddhaarta 1 Quote Link to post Share on other sites More sharing options...
